700r4 dipstick length??
beachsuburban
Delaware
J
v2500
Hey guys, just got my trans rebuilt and it's running great!! However the shop told me it has the the wrong dipstick... What I have is a 1992 700r4, does anyone know the length of the one it needs? I would like to confirm, and if it is wrong, be able to make sure the new one is right... Thanks!!
74 Shortbed
Depends on how long the tube is, I have one 25" and one 33"..
beachsuburban
Delaware
J
v2500
Crap, I knew this wouldn't be easy... So the tube is around 33" (hard to exact measure) the stick is 33 1/2 from the bottom of the red handle part # on it is 15687192.
74 Shortbed
Well, stick usually sticks out about a 1/2" past the tube and the tube is about 2" beyond the case. Myself I would pop the tube out and see where the end of the stick is.
beachsuburban
Delaware
J
v2500
That would be way too hard. The shop used a lot of rtv to seal in the tube, it was messed up from it's past, and was leaking there. It's pretty much sealed in for good.
CSFJ
That's not a good sign. There's usually a grommet or o-rings to seal the tube. Slopping a bunch a rtv on it isn't going to be a long term solution.
74 Shortbed
What kind of shop is that???, nobody puts RTV there that's gonna leak for sure, bet that'll pop right off too, that's another good reason to pull the tube and put the appropriate seal there..
yevgenievich
Place
Name
Year
Model
Size
It is possible that the tube is damaged on the end and the regular seal could not seal around it. The best option might be to buy a new matching tube/dipstick/seal and install.
beachsuburban
Delaware
J
v2500
Hmm.. So the shop has a solid reputation and a 1 yr. warranty, problem is they have transmission skills, not good at the social part. They told me to go to a junk yard and find a newe one. Which is why I'm here.
CSFJ
I think I would have some serious issues with a transmission shop that can't locate transmission parts.
yevgenievich
Place
Name
Year
Model
Size
They might be just offering the cheapest solution that a lot of people seek instead of communicating the purchase of new parts.
74 Shortbed
X2... Can't believe a shop would say that, and very hard to believe that a tranny shop don't have a bunch of em laying in a pile somewhere, I even have a few lying around, lol.
beachsuburban
Delaware
J
v2500
You all make sense to me, I completely agree... Thing is $1400 for a performance rebuild with a 1 yr. warranty and he is the only guy around. He looked for one and couldn't find basically he said any 87-92 at the junk yard will work.
74 Shortbed
They all will work because the end in the pan are all the same depth in the pan, it's a matter how high you want the tube to stick up as far as length goes.
beachsuburban
Delaware
J
v2500
So they only made 2, the 25" and 33"? Thinking here then, just make sure its the bigger one and should be good ?
bvandrey
