theblindchicken
- Oct 24, 2013
- SoCal
- Christian
- K10 5" lift + 2" BL
- 350-4, 0.030" over
Yup. So many different styles and varying difficulties. I personally prefer trails up in the forest and mountains. Mainly because that'a what's closest, but the scenery is always enjoyable.You know Christian it's all relative. Some guys live in the flatlands and to them 4x4 = a muddy road. Some guys use their trucks in ways that
are unimaginable to mere mortals.
Some guys (ME!) can destroy an aluminum rad from gravel roads. Like try driving 80mph down a logging road drifting and sliding on gravel,
the gravel sprays up under the engine compartment and stones make it up to the fan and 'bing' there's a pin hole in that aluminum rad.
Everyone had a different idea and location specific mods are pretty normal.
Some guys just want to rip up deep mud, and articulation is not so important and can actually cause drama in deep mud pits.
Here is my tire/lift formula that works for my general off road intensity...
Based on 35" tires...
4" springs, Tough Country at least or ORD custom multi leaf flexy buggers.
1" EZ Inch or Zero Rate (ORD again) moving the axle forward.
Make sure cab is as far back as it will move on the mounts.
8.5 or .75" rim width by 16". 4.5" (stock) backspacing.
1" body lift.
trim front fender from the side marker light down.
I can still put rubber to metal with this setup if I try, but for most of my needs I'm good to go.
So thats a mix of fire roads, rutted trails, and a bit of some twisties. She's not gonna be a rock bouncer, and i'm not trying to do any sled pulling either. Just be able to go where I wanna go and have fun doing it without much breaking is all I'm looking for.
