6.2 diesel to gas engine.
custodian
Catawba
William
5.3 LS, 350
I bought an 85 SWB with an AT and 6.2 diesel and will be switching to a 350 gas. I'll be replacing the gas tanks. Will the wiring harness have to be replaced? Anything else that will need replacing? ETC?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I’m assuming this is going to a run of the mill carb, HEI setup? No fancy EFI, TBI, etc.?
custodian
Catawba
William
5.3 LS, 350
Yes, Carb and HEI. Nothing fancy. Giving this truck to my youngest granddaughter.
Rickf
Grafton NH
1974, 1954 & a 1937
Should be able to adapt the 6.2 harness to gas. Injector pump wire will power the HEI, water temp sender may need extending, if the carb has an electric choke you'll need to supply a switched & fused 12 volts. Won't need glow plug wires.
This sounds right. I've been told a few times that the harness is roughly the same, just different lengths on some connections.
Dmack
Central OR
Dave
Mine has the conversion before my son bought it. Hope you do a cleaner job. They had pulled the ignition switch off the column, then drilled two toggle switches in the dash for ignition on and starter engage. The harness was butchered. I swapped in a factory harness.
custodian
Catawba
William
5.3 LS, 350
Thanks. Sounds very straight forward. Will not cut any wires.
K5ride
Apple Valley, CA
Steve
C10 Stepside
I deleted my post due to misinformation.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
The 6.2L is not the Olds diesel. I has Chevy bolt patterns.
Hondo78
3500 crew cab dually
The 6.2 tanks should work fine with a carb I'm sure the diesels don't have a fuel -pump in them.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
You'd probably do well to change the pickups if you have evap. Also, the screens on diesel pickups are different. Don't know if that would cause a problem, but they have a relief valve that gassers don't.
K5ride
Apple Valley, CA
Steve
C10 Stepside
@ Blue Ox......... OOPS...... your right. After seeing your post, I looked it up and it was the 5.7 diesels that were made by Olds. I guess my memory isn't as good as it used to be....LOL.
Hondo78
K5Ride
Easy mistake: The 5.7d and 6.2d Diesels were originally great engines for the time, however back then GM had a planned obsolescence plan that cheapened the original concept. A former neighbor now 90 years young, had both his original Oldsmobile 5.7 diesel wagon and a GMC 6.2 diesel step-side half ton, till he stopped driving last year. He was an Oldsmobile engineer on the diesel program.
custodian
Catawba
William
5.3 LS, 350
Any tips on starting a diesel that has been sitting for along time? Going to see if it runs before I take it out.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Is it in the truck?
MenDeeZee
