- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
The throttle body was running when it was removed but it's been sitting on a shelf for years now. I would assume the TPS and IAC are still good but it may need a gasket kit, no idea about injectors once they've sat so long. It's dirty and dusty but NOT beat up.
The adapter appears to be cast iron so it's fine, just surface rust.
I'll be honest, I'm on the fence about selling the stuff so I'm not going to give it away but if you're interested pm me and maybe we can work something out.
If you're on the fence with it, just hold onto it. I'm sure there is someone like Imann who is done with it for sure and ready to throw it out. I hear of peope converting to carb all the time. Being this can be swapped later on, I can still put the truck together as the carb motor that it is then Retro-Fit the TBI later on as I acquire the other parts needed. Just that I'll be putting it together with the TBI conversion in mind with steel fuel lines, TBI tank etc. Thanks for the detailed pics. Gives me a better idea of what I'm looking for.
