454 in 79 K-10. Engine specs
Alaska 79 K-10
Fairbanks Alaska
Bryan
K-10
I recently rebuilt the 454 in my 79 K-10. It is a .060” over 1973 block with a steel crank. Hyper-eutectic Speed-Pro pistons on 502 BBC rods. Compression is 9.7:1. It has 049 heads, Comp Cams hydraulic roller 11-451-8, and roller tip rockers. Factory iron intake, and an Edelbrock Q-Jet carb. HEI ignition, and Hooker headers. Puts a smile on my face every time I drive it.
Shorty81
Baby Boomer
North West ohio
Darren
I recently rebuilt the 454 in my 79 K-10. It is a .060” over 1973 block with a steel crank. Hyper-eutectic speed pro pistons on 502 rods. Compression is 9.7:1. It has 049 heads, Comp cam hydraulic roller, and roller tip rockers. Factory iron intake, and an Edelbrock Q-Jet carb. HEI ignition, and Hooker headers. Puts a smile on my face every time I drive it.
Looks awesome!! Love it!!
AKguy
Alaska
Randy
K30 Crew Cab Silverado
Beautiful. Which headers are you running?
Alaska 79 K-10
Fairbanks Alaska
Bryan
K-10
@Alaska 79 K10,
We were in a discussion the other day about semi-gloss paint. So what paint did you use, it looks great.
It is a semi-gloss urethane that can be bought at NAPA stores that sell paint. Kinda spendy, but the sheen is just right, and super durable. The mix number is 70-8800. Must be sprayed through a paint gun.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Love the 454, but seems like the ford guys around here have more money, as I did the internal work on a .030 429, and a .040 460, this week. 4.401 finished bore...About the same size as Double D's, in case Idahovette has trouble with the numbers...Hey Perry.
Oliver90_08
