454 BBC Bare Block & Heads .060 Over
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Hey guys. Iv had this big block sitting in my garage for several years now and Iv decided Im not going to do anything with it after all. I did a little research on it and found out its a late 70s block which makes it either a Mark IV or VI (I don't remember). I bought the motor bored .060 over and it comes with a set of bare cast iron heads. Motors been covered up, sitting indoors. Does have a small bit of surface rust in one of the heads. Im sure it would clean up just fine.
$500 obo - Willing to deliver for a small fee within reasonable distance!
MrMarty51
Eastern Montana
Martin
Is eastern Montana a reasonable distance ??? :shrug:
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Halfway is lol
I wish I could figure out the smilies on here! I was gonna say "Halfway is (smilie with thumbs up)" lol
That will be a 2pc Rear Main Mark IV block.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
^^^ What he said! Lol
But I think you mean 2 bolt mains lol
MrMarty51
Eastern Montana
Martin
Halfway is lol
FAK !!!! the wifey do`n want Me bringing in anything else, I`m flat busted, not only that I dont have some money.
Click on the advance button under Your reply area, there will be some on there, also in the lower left corner is a "More" button that bring You up a whole page ofum.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Ill knock off $100 if you can convince your wife you need it :waytogo:
Found the button! For whatever reason, its pretty well white against a white background lol. Now I can smilie everything!!! :signs6:
MrMarty51
Eastern Montana
Martin
My nephew just drove about a 90 Chevy 1500 4X4 over and told Me He did`nt want it any more, FREE !!!!, a perfectly good running 350 and a manual transmission, complete pickup. The wifey give birth to a cow about that, She wants no more vehicles in the yards, for any reason, free or not, and affer I got the 79 together She had another cow about how much parts was.
I just dont get any respect I tell Yuh.
Here 89, I `ll even doit fuhr yuh. :nutkick:
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
I believe its a 2 bolt main if I remember correctly
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Bump! Someone on here needs this engine!
Yep, somebody does. It's .060 over. Add a $1600 BALANCED rotating forged stroker crank, H Beam rods and .18cc dome forged pistons kit and have a Nitrous 496 cu in motor that will easily make 500hp on the motor and 700hp with the bottle and button !!! That should net a light half ton squarebody in he the high 11's low 12's with a locker or spool rear end on slicks or drag radials.
That's with the right, heads, cam, intake and exhaust of course too.
When you mention this block is .060 over, do you mean it's a fresh bore as in just out of the machine shop and ready to build, or is it used and has been tore down? Have you looked to see if it's it's 2 bolt or 4 bolt for sure? All the Main caps there in their respective position? Are the main caps marked?
What is the cast # on the bare head cores? Honestly, now days bare head cores just aren't worth much since by the time you bought all new valves, vavle guides, guide plates, springs and keepers, you can buy a set of of aluminum aftermarket ready to bolt on and haul ass for less money.
BUT.... If someone has a set of cast iron heads that cracked from an overheat and yours not cracked, then they can transfer all their valvetrain to your good cores. So I think I'd find those cast #'s on the heads and post them up too.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Iv owned this block for approx. 5 years so its not straight out of the machine shop fresh, but it hasn't been assembled/ran since machining. Ill run out to the garage and get all the numbers and such and let ya know
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Ok here we go. I believe the block # is:
3999289
With other numbers:
C22-78
And the heads:
3933148
With other numbers:
2254
CM4T
M Truck
The heads look like square bore on the intake and oval on the exhaust lol
GP2024
