406
Square 78
Alabama
Heith
K15
I just recently purchased a 78 k15. With a wore out 350. To day I purchased a dart shp block with a 406 roatating assembly. With a set of afr 195 heads with 75 cc combustion chambers. With the pistons that came with the kit it’s suppose to give me 9.5 to one compression. I didn’t wont much more because most of the gas stations around here close 89 is the best you can get. Ive still not made up my mind on cam intake or headers. The heads are set up for hyd roller. Planes are 35 boggers and a set set of gears. I wouldn’t mind a little bit of a stall. Any help would be appreciated. Will be driven on the road. So I won’t it to have good manners in town.
4WDKC
Southern Florida
Kacy
plans? mud toy, tow pig, mall crawler with 35s you will need 410s to not be a hazard when pulling out in front of cars, 456s would be better.
Square 78
Alabama
Heith
K15
Honestly all of the above I guess you could say. It won’t it to be able to do pretty much all of it.
Square 78
Alabama
Heith
K15
The main thing it will be used for really is running old dirt roads and going in river bottoms. Mud will be bad roads will be awful. Like I said any help would be appreciated. I’d like to get the carb intake and cam all at 1 time. I’m really looking for quick snappy throttle response. Thanks again
4WDKC
Southern Florida
Kacy
mud toy is high rpm hi hp usually high compression also
tow pig is lower compression and high low/mid range torque
mall crawler is stock motor with thumper cam for sound not performance
you need to measure how far in the cylinder the piston is at tdc to get compression figured out, once you have those numbers, you will need to know the stall in your torque convertor, gear ration and guestimate of weight before you can get a cam recommendation. Without these you are guessing that it will perform correctly and may it not.
BESTCHOICE
