4" lift 33's or 35's?
GoBucs
Laurel, md
Nick
Im sure this question has been asked a million so sorry in advance but im torn. Im planning on lifting my truck 4" with a rough country kit and buying a set of dunlop mud rovers in 33 or 35x12.50 (on stock wheels for now). Just cant decide which. Ive read about guys fitting 33's on stock suspension and im afraid if i go that route they'll look too small. At the same time i like things looking porportional and i think 35's will look too "stuffed" in the wheel wells. I just dont want to spend 800 bucks on tires and end up having them look goofy. I was considering going the 35" route and adding a 1" body lift from offroaddesigns. But the less i have to spend the better. I'm assuming a total of 5" of lift will clear 35's with minimal to no rubbing? Im also somewhat worried about tearing up the 10 bolt rear/44. I've read 35' is the max size people recommend running. The truck is'nt used for any heavy offroading. Thanks for any help guys.
Here's some info on the truck; 87 v10 single cab, long bed, 350, sm465 3:42 gear (will change to match tires soon)
Thanks again!
Since you're running stock rims with a stock offset, I'd say you're most likely OK to go 35's if that's what you wanted. Running the SM465 manual trans, you're OK to run the 35's too w/ 3.42's. If you were running a 700r4, I'd say NO. That's just my .02. Stock wheel offset, and SM465 w/3.42's, run the 35's if that's what you want. Go For it.
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
with a 4 inch lift id say definitely 35's, it doesnt look too stuffed to me. 33s would look too small (i personally dont like a jacked up/small tire look). if you wanted an extra inch id get the zero inch add a leaves instead of a body lift :doublepuke:
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Why mud rovers? There are far better choices for tires on the market.
Swims350
Logan WV
none
35's for street use or mild to moderate offroading maybe, if you want some hard core wheeling, flexin and wider/less backspace more offset wheels later, do 33's but they do look too small.
had it on stock rallys, rough country 4 inch lift, 33's way too small. I wished we had 35's.
GoBucs
Laurel, md
Nick
Cheapest mud tire i could find new. Ended up paying 820.33 shipped for 4 35x12.50r15's. not too bad.
chubble
Eastern, NC
Custom Deluxe K10
Can't wait to see pics
Swims350
Logan WV
none
where from? 200 hundrd a piece is a good cheapest going rate on 35's not to mention shipping so where were they ordered from. I need a set the same size.
GoBucs
Laurel, md
Nick
Tirebuyer.com...googled discount codes you enter at checkout. Ended up at retailmenot.com. Used a code for 12% off an order over 800 "retailmenot12". They have others aswell.
GoBucs
Laurel, md
Nick
Best part is i ordered them yesterday and fedex is scheduled to deliver today. Though it looks like they're only coming from one state over.
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
if you do the proper bumpstop setup if should be fine, i had to get new bumpstops and put a spacer in order to prevent rub/ bottoming the shocks
carlgm
Fl
Karl
'85
Looking forward to seeing the pics. Just curious how it look like because planning to lift my rig as well.
mb84c10
Maine
Mark
If its on road truck 35s will work but like stated will rub offroad.. I had 3" lift and 33s on stock rallys looked good didn't rub. Then added another 4" 36" swampers offset wheels and they rubbed offroad some.
mb84c10
Maine
Mark
That truck had older 12bolt rear welded and d44 front setup with 3.08 gears too was fine on road was a dog offroad tho in deep mud. Only thing I ever broke on it was front axle joints..
