390 Cylinder Bore and Piston Diameter Issue
davbell22602
Bunker Hill, WV
I Dont
Have
One
I was going over my 390 block today. So pulled everything down to the bare block. I went to measure the inside diameter of the cylinders with a telescopic gauge then measured it with a outside micrometer and I got 4.077 on all 8. I went to to inspect the pistons and found that they have "30" stamped on them meaning 30 over. So measured the diameter of the piston with 4-5 inch micrometer and got 4.077 on all 8 pistons. I have 4.050 for stock cylinder bore. Does that sound right?
There are some surface scratches on the pistons on the side where the wrist pin doesnt go through at.
Here's a pic of pistons
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I think you might want to double check your measurements with the mic. That's a HALF INCH larger than they should be if your measurements are accurate.
Dude, that tray is neat that holds the parts.
davbell22602
Bunker Hill, WV
I Dont
Have
One
davbell22602
Bunker Hill, WV
I Dont
Have
One
Fixed in post #1 on the piston diameter.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Yes that sounds right... 0.003 wear on the pistons if they were 4.080" (minus 4.050 = 0.030" overbore). I would snap gauge 3 depths of each cylinder parallel and perpendicular to the crank and check for out-of-round and out-of-taper while you're at it.
davbell22602
Bunker Hill, WV
I Dont
Have
One
OK, A .0015 piston feeler fits between the piston and cylinder wall but its tight fit.
JOD26
