350 engine what fits it
Swims350
Logan WV
none
yes the only pan on the trans the trans fluid pan.
roll it over and get one from as you would see with it in place under the truck looking up at it.
a 700r4 has a squareish pan and a 350 is squae with one corner 45'd off it.
chevy murf
joseph
v8
chevy murf
joseph
v8
chevy murf
joseph
v8
chevy murf
joseph
v8
I took a lot of pictures is that enough to identify what type of transmission it is????? Thank you again for all the help
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I would say that is a turbo 350 and with that short shaft probably had a 203 t case behind it
in 1985 gm changed the transmissions so they all used the same driveshafts
you could put a 700r4 400 350 or the long tail shaft 465 in your truck if you find the right combo of parts
hell you can even put a nv4500 5 peed 4l80 or even a 4l80 in your truck with the right combo of original gm parts
I have swapped a nv4500 into a 85 and used all gm parts and a 4l80 with only minimal modifications
chevy murf
joseph
v8
okay one more question what exactly do i have to do to get a 400 turbo tranny in there???
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
its hard to say exactly what needs done until we know what tcase you have with the 400
you might have to drill new hole in your frame for the cross member
if you have a 208 t case to match the 400 your stock shifter will work
if you have a 205 or a 203 you will need to cut a hole in your floor for the shifter
you will need to get a 400 and the transfer case that fits it and go from there
chevy murf
joseph
v8
I just went with rebuilding it. worked out great
imyourhuckberry
