3 port fuel tank selector valve
Alaska 79 K-10
Fairbanks Alaska
Bryan
K-10
For the three port fuel tank selector valve use a NAPA part number 2-2057.
Juggernaut
Illinois
Greg
All of these 3 port universal solenoids I have found have been for 5/16 hose. I found one from Summit that was listed as 3/8, but when I got it, it was also 5/16. I had to go to a 6 port, then just capped off the unused ports.
I thought the early style 6-port was the one that was not available new?
Juggernaut
Illinois
Greg
I got mine from Rock Auto. I had to do some rewiring to make it work
So it was the later style one then? Not the type with a single wire hookup.
78C10BigTen
pennsylvannia
C10 BIG TEN
Thats one issue i find, im not trying to wire in that big long plug. I want a direct replacement.
Dave M
Banned
Australia
Dave
The replacement type is the one I finished up changing to. Works fine with the 3/8" hose. I did wire it through a relay and fuse though, in the event of the solenoid coil burning out. works fine.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Mine does not work, so interested in this....
Raider L
Shreveport, LA
William
Is this for a duel tank truck? I've thought about going to two tanks. Classic Trucks and NPD has the tanks and fuel lines and all that but it still looks like a pain to install. And now ya'll are saying the three port valve isn't available? I have a fuel tank with three hoses on top and I can get the same for the other tank. There are some that are four hose tanks and I think they may be for the two tank set up but I'd have to study it some more.
So where else can the three hose valves be found? By any chance does Chevrolet still have duel tank trucks and may offer this valve for them? Or have they gone super complicated like everything else with vehicles these days, all computerized?
The standard 6-port setup would be for a three hose sending unit. You have feed, return, and vent. The vent goes to a wobble valve or the charcoal canister depending on emissions, the feed and return from each tank go to the switching valve. Early 6-port(like mine) are a single wire activation that grounds through the body of the valve itself.
Almost every year could have had either 3 port or 6 port, especially early years. The later years went to almost exclusively 6 port to remove vapor lock issues that occurred with the 3 port setup and the lack of return line.
Its also important to note only long bed trucks have enough room to fit a 20 gallon saddle tank. All short beds can only fit a 16 gallon on either side due to the forward rear spring mount being in the way of the larger tank on the short bed trucks.
duplicate post
Raider L
Shreveport, LA
William
@Bextreme04,
Oh, so that's why when I'm looking up tanks to use there are either a 16 gal. or a 20 gal. tank. I didn't know what the short beds used and I guess I assumed they were the 16 gal. tank, but see the tank in my truck, '74 is a 18.5 gal. tank. Another oddity for my truck on top of all the other odd ball off truck parts I've discovered on it, i.e. 1/2 a Z28 motor...for real, 4x4 springs, etc. It could be the fact that the first half of the '74 year was kept points type distributor like mine was and the second half of the year went with the new HEI dist.
So maybe there were other changes GM was making for the way all pickup trucks were going to be, like the heavier springs like mine. Why have light duty springs in one model and heavier springs in another model? They knew people were going to load the crap out of these trucks so why not put the heavier springs in all of them to begin with and then you'd have a more durable pickup in all models.
imyourhuckberry
