3.08s and 33s
Gavin.reid
US
gavin
Okay so I have an 81 chevy k10 with a 10 bolt front and a 12 bolt rear with 3.08s what's the biggest tires I should run? I'm not going to be doing much highway use mostly just offroading I would need to be able to drive 60mph for a little while occasionly.
Sent from my SM-N910H using Tapatalk
Craig 85
Nashville, TN
454/TH-400/NP205
My 79 1/2 had 33's with 3.08's. Definitely not fast, especially with all the smog equipment, but did OK. I turned about 2000 RPM at 65. I swapped to 3/4 running gear with 4.10's and 33's. Better off the line and up to freeways speeds, but I was then turning almost 3000 RPM at 65. I think my truck had the factory 150 HP 350. It didn't have much to give after 60-65 MPH.
Gavin.reid
US
gavin
I should be fine then not really looking for speed anyway and my 350s mildly built closer to 325hp
Splandman
Crescent, OK
Scott
What trans? I assume a TH 350 or 400, because I have 4.10's and 33's and only turn 2k at 65, I have overdrive though. At least I have it for a few weeks at a time until trans goes out.
Gavin.reid
US
gavin
I have an sm465 and 3.08s how do you think it'll be for 33s off-road not much on road
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Depends on what kinda off-roading your gonna do.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Mostly mudding and a little rock crawling
Low range in the case and 1st and 2nd for crawling and low range and 2nd for mud and keep the Rpms up. I have 36s and 373s and a big block with a th400 and 262 low range but I'm just playing in the mud. Well will be soon.
Gavin.reid
US
gavin
Sweet what size lift you run for 36s?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
6" and 2" body. Spring up front and add a leaf and shackle flip out back.
Craig 85
Nashville, TN
454/TH-400/NP205
Mine was a TH-350.
Mr. Gutwrench
Lee
Your crawl ratio is around 40:1-52:1 (not sure which transfer case you have). Generally, rockcrawlers with a standard trans shoot for 100:1. My rock buggy with an auto was 55:1 crawl ratio and 39" tires and worked well for Western rockcrawling. Not sure the ideal for mudding, but it seems like you would be close. Mudders would want a higher ratio (lower numerically) for wheel speed.
4WDKC
Southern Florida
Kacy
3.42:1 with 33s was like 2500 in drive at 70, with the 700r4 first gear it was not fast off the line 373s or 410s with 33s.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Sittin around 2800ish at 60-65 on the hwy for me.
TH350/NP203 with 4.11's and 35's.
60Denais
