2 wd to 4 wd cab
Erie pa
Michael
Scottsdale c10
I was wondering when y'all put your 2 wheel drive cab on a 4x4 frame what amount of body lift did you use not cutting my hump out sense my floors are very clean I hear 2 inch I hear 3 I her 4 has anyone actually done this that can give me a solid answer and I don't have to buy body lift after body lift to get the right one lol....thanks
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
There all different. I would imagine different transfer case/transmission and linkage setup would come into play.
Earlier year 4x4s had bolt in driveline humps. My recent parts truck was an 89 cc and the hump is integral to the floor
pan so out came the zip disk, cause I need it for my 2x cab.
If your lucky a 1" body lift might do the trick, but I doubt it. And please don't ever go over 1" unless it's a mall cruiser.
If you're working your truck in any way shape or form, 1" body lift is the ****. Even if you don't need this little extra clearance,
it's still beneficial.
Don't listen to anybody else here that says otherwise because they're wrong.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
If 1” is **** then 2” must be **** on a mule then.......:D
Ndkshns
Pryor
Gilbert
About to do this myself and have never done it. What is different other than the hole for the 4wd shifter on an automatic? My 2wd floors need replaced anyway... so is it just a matter of ordering a different floor plans?
75gmck25
Northern Virginia
Bruce
Have you taken out the carpet and looked at your floors? On my '75 the center section of the floor is bolted in, and it has a raised area on the hump to clear the transfer case. I'm not sure what an '81 would have.
Bruc
Ndkshns
Pryor
Gilbert
I havnt yet, I just saw a post about doing a 1" spacer lift when doing the conversation so it got me looking to see what it was all about. I did a search but couldn't find anything on it.
I've heard with a 700r4 and NP208 no lift was needed but it was tight and I have a feeling they used the spacers between the frame and crossmember to make that work, and I've heard 1in is all you need. I think it really depends on the tranmission and Tcase.
