2 mysterys to me
77chevy400
Eastern NC
6.6l (400)
I have a old farm truck that needs a little tinkering but the day i bought it i stuck the kry in went somewhere parked. Got out and the chrome key piece that u turn to start fell off. How do i reinstall this piece without pulling the steering wheel to install it or a new ignition lock cylinder?.
Ive tried aligning up the slot on it bit it wont go in straight not even if i tap on it.
Also i found these #'s on my intake 14007376. GM K8.
What engine do i have. Ive looked for engine block numbers but no luck.
I was told that it was a 400 motor. Im not sure a 350 intake fits a 400 motor so im believing i have a 400 sbc in it. Plus the torque and power from it makes me believe so. Ive never drove a stockish 350 that put out like this. Even though my 4 barrel dont work. (Only 2) factory quadrajet and for the life of me i cant figure out if its a double pumper or vacuum control. Im missing alot of vacuum lines and on top of all that egr valve is blocked off but since i tuned my carb i cant tell its bad on gas. I could guess its 15-20 mpg
Sent from my Reddot R50 using Tapatalk
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I think your gonna have to get a new ignition switch assembly not sure though
Easiest way to tell if you have a 400 and look at the harmonic balancer it has a large indent for balancing purposes, it doesn't look like a 350 balancer which is perfectly round all the way
77chevy400
Eastern NC
6.6l (400)
Indent being on the edges or the face of it.
Moderator
I had that chrome piece fall off once, I cut a key that was the mid 90's car style that had the big "handle" on it. It made it easy to turn. But I did end up replacing the ignition lock to fix it right.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
The outside ring "on the side of it" Im having difficulty trying to explain right now haha :sorry:
77chevy400
Eastern NC
6.6l (400)
Thats what i feared. Ive replaced one before but not on something this old.
I know u have to get a steering wheel puller. Any ideas to make this a smooth installstion. Ive read some ppl had trouble with a plate in there??
Im also going to ditch thr stock steering wheel. Literally how do u know if a aftermarket steering wheel will fit?
Splandman
Crescent, OK
Scott
The Grant wheels have an adapter kit to make them fit our trucks.
chengny
Some info on the lock cylinder - from the 1977 service manual that might be of help (includes the directional switch R & R procedure - unfortunately it has to come out to service the lock cylinder):
I am guessing you know how to pull the steering wheel (or could figure it out), but just in case you have trouble:
Moderator
The lock plate tool can be bought at most parts stores. It's cheap too.
77chevy400
Eastern NC
6.6l (400)
What exactly makes the lock plate so hard to install that u must have a tool. Ive pulled steering wheels but none of which i needed a special tool to re-install it.
firebane
Calgary, AB
Curtis
Lock plate tool is required because of the fact the plate is held in with a c-clip if I remember and under pressure from a large spring. Without the tool your not getting it off.
Moderator
Right, you need it to get to anything after the steering wheel is removed.
crowe-t
