1994 S10 1Ton SAS
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
We don't have a Lazer or plasma at the shop, so I just mill these brackets into the tubing and leave a little .020-.03 web, and that'd easy enough to take a cutoff and just free them from the tubing.
Sent from my SM-G965U using Tapatalk
Maybe a dumb question, why not just mill them all the way though?
Vbb199
Salisbury NC
Vince
Sometimes with cold rolled steel, it likes to stress relieve when you mill it from its natural shape And it will have a tendency to "jump" out, I've done it a few times before, like with the k5 sway bar arms, I took 4 plates, welded them together, drilling the holes I needed in them, and then bolted them directly to the table.... I didn't mind doing it that way because there was no way they could stress relief
Vbb199
Salisbury NC
Vince
You can see it here @bucket
Look at the warping!!!
They didn't warp the other way however, it's general a linear warping, not so much the other way.
Vbb199
Salisbury NC
Vince
Shackle hangers are made.
Vbb199
Salisbury NC
Vince
I have the shackle hangers tacked to the 3x3 square tube.
I have to go and saw off a little excess, but I think the general idea is given here. They're setup 36.5" on center for a Ford 1 ton front.
Vbb199
Salisbury NC
Vince
Now it's time to finalize the welding.
Vbb199
Salisbury NC
Vince
Arc Weld quality: sub standard [emoji23]
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
We'll let you by on this one...
I would peen it with air and then do a cover pass low hyd..
Or just clean it up better and get on with life.
Vbb199
Salisbury NC
Vince
Bleh, I'm not too too concerned with the way it looks, I did 2 passes
Vbb199
Salisbury NC
Vince
There's that abomination
Looks really only matter if it falls off, lol. That ain't going anywhere.
Vbb199
Salisbury NC
Vince
First pass I filled up the gap nice and slow, beat all the slag off and cleaned it up, second pass was a little higher amps, nice slow fat welds with 7018
Vbb199
Salisbury NC
Vince
One more shot, that at least concludes all of the hardware needed to bolt the front axle up.
Vbb199
Salisbury NC
Vince
So, 1 tons made it in last Friday, two dana 60s, a 87-91.5 kingpin 60 and a 95-97 balljoint 60, that I have just for spare parts.
99-06 14 bolt ff rear, disc brakes with E brakes.
flynhigh88
