1987 V10 stalling when gets to temp, cutting out Code 34?
Matt Isard
Michigan
V10 Silverado
my 1987 1/2 ton Chevy is stalling our after a few miles. Won't restart until I let it set and cool down. Its jerked a couple times going down the road, but not stalled.
I plug in a code reader and get a code 34 (see attached pic)
MAF (mass air flow sensor)
MAP (Manifold absolute pressure)
Pressure sensor unit
Any thoughts would be appreciated!
Snoots
Roger
Jimmy Sierra
How old/dirty is your air filter? Then we can go from there.
Matt Isard
Michigan
V10 Silverado
How old is the coolant temp sensor on the intake?
Good question, I just bought the truck, new crate motor, Ill look at sensor
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I only ask because its possible the code 34 is a result of the issue, not the cause.
The CTS (has mutiple wires, top of intake) has alot of say in fueling for the motor....
You said engine temp rises and then it wont run anymore until it cools down. Once the motor heats up on a normally operating tbi engine, it eventually trims fuel back once it reaches the ECMs set "ideal" temperature.
Whats the exhaust smell like when it reaches temp?
gmbellew
Kansas city
glen
suburban 1500
I'd get into the service manuals in the reference section. the emissions and drivability manual is where I would start.
gmbellew
Kansas city
glen
suburban 1500
i would get into the service manuals in the reference library...specifically the drivability and emissions manual
Twistedwhisky
