1987 drag link
Travis
Bowling green
Travis
I have a 1987 r10 and I need a drag link but they don't make them anymore the ones I find are wore like the one I have now needed to know if I can change to another model and what I needed to do to accomplish that or ?
They don't make them anymore?
Travis
Bowling green
Travis
Yeah what I was wanting to know is if anybody knows what options I might have to change it or what I could do
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Straight axle it and use the above drag link. :lol:
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
You will likely have to make this a junkyard find.
Man I can't believe this part is not available anymore. :(
Can a machine shop repair a damaged one?
Travis
Bowling green
Travis
You can find them at junk yards but all bad can weld the pieces together but no going back gonna try to piece something together from other years if it works I will put the winning combo online so we can spread the word
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I can't really see how it would get worn out and be bad on all of the trucks...the idler arm, pitarm arm, and tie rod tapers should lock into the taper on the drag link. All of the wear should be occuring in the sockets of the tie rods/idler arm/pitman, etc. The drag link off of my 87' is pristine in the tapers.
Moderator
Agreed. It's no longer available because it's a non-wear item. Only time they get screwed up is from getting wrecked or people leaving nuts loose when they replace other parts.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Lol what did the rest off the truck look like?
Gurn
