- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
im pretty sure i recall having this convo with youI thought I could live with the 650 idle but I can’t anymore. How can I bump up the idle some? If I leave the truck idling at 650 and walk away and come back the truck will have stalled by the time I return. It’s also sketchy rolling to a stop idling so low and the truck basically shutting off but never completely stopping. It drops significantly in rpms to below 400 and pops back up sometimes (usually before stalling) what could be causing this? I really need atleast one truck lol one doesn’t run and this one doesn’t steer right now.
your truck if its dipping that low has something wrong
if your truck is dipping low, its often possibly an alternaotr which output if it vastly dips limits your spark power and if you have sensors it pulls them low
you have an ECM, and you have a 12 si on this truck iirc.
get a CS130/CS130d/AD230 and run a sense wire to your junction block and the charge wire to your junction(It runs to your battery, doesnt it?) and stop plaining
or go back to our discussion because the specific things I told back then, some were googled and I dont really want to research things again if we are just going to go in circles lol.
You also need to verify all your grounds, and by saying that, save time and add them. GM made them lousy from factory and any corrosion bites into the ability. if you add grounds properly they can have corrosion over time and maybe still not swing your system.
I dont remember if we looked up your MEMCAL/PROM id but if you send your VIN ill show you what GM says it should have based on a website
