- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
Tomorrow I plan on driving the truck down the road and seeing how the temperature acts. It was getting warm today but never got to 260 as far as I saw while trying to get air out of the system.
The pulsating pressure in the upper hose and all of the other things you have said make me think the water pump is probably not in good shape. You are probably getting not nearly enough coolant flow through the engine and its getting localized hotspots. I would change the water pump ASAP before doing any more driving. I would also look at getting a better fan.. that three blade is pretty weak. The mechanical idle with the A-B pins shorted should be 650rpm. The IAC valve should then be pulling idle up to ~750rpm. Change the IAC and then do the IAC calibration and idle set procedures. Get a timing light and actually adjust it properly.
