1985 C20: Carb not getting fuel
1985C20FLATBED
CT
sam
Hello all,
I have a 1985 C20 with a 350 and auto transmission. Truck is completely stock.
I have power to the key and the truck wants to start. I am now looking into the carb because we don’t think it’s getting fuel. It has a new fuel filter and I have a new carb mounting gasket on the way. Any other suggestions? Thanks!
legopnuematic
Licensed Junk Dealer
MO
Spencer
Pull the fuel line off the carb and insert into a bottle, crank truck for a few seconds.
It should fill the bottle up a fair amount. If it does the fuel pump is ok and getting fuel to carb, if it doesn’t fill the bottle or very little, check fuel pump and connections from pump rearward.
1985C20FLATBED
CT
sam
Thank you. I gave that a try and a good bit of fuel came out, so I believe the pump is good.
1985C20FLATBED
CT
sam
What do you think I should look for next?
legopnuematic
MO
Spencer
What carburetor is on the truck?
If you have good flow to the carb, hook the line back up and crank for a few seconds, then while staring into the throat of the carb (likely will have to Hold the choke flap open), cycle the throttle lever on the carb a couple times, this will pump the accelerator pump. When you work the throttle you should see fuel spray.
If you do see fuel spray, that says the accelerator pump is working and that the needle and seat is allowing fuel into the bowl.
Sad Sack
Nebraska
Goober
C15
Should be a long paper gas filter. Did you put it in backwards?
1985C20FLATBED
CT
sam
I put a new filter in, ill check again but pretty sure its not backwards
1985C20FLATBED
CT
sam
1985C20FLATBED
CT
sam
No fuel spray from what I can tell, don't smell gas either
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Fill the float bowl with fuel. Try and start it. With the float bowl full, it should run long enough to pull fuel from the tank. If not, check the fuel lines. Make sure you don’t have one kinked, or corroded.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Any time my carb lost its prime I would need to pour fuel straight into it to get it started. After a start it would stay primed.
Also
At one point my tank switch valve went bad, it would lose prime trying to suck air from whichever side tank was empty so I bypassed the valve and only used one side.
1985C20FLATBED
CT
sam
How much fuel should go in the float bowl? I've read about a cap full but want to be sure
1985C20FLATBED
CT
sam
Also
My truck has one tank so I think I should be ok
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I have no clue how much fuel a Q-Jet float bowl will actually hold. I’m guessing a 1/4 cup or so.
If it's s qjet with a vent hose to the charcoal cannister.,I pull the vent hose off at the carb,and fill the carb through the air horn vent using a mustard bottle or dish soap bottle full of fuel,until fuel dribbles out the vent hose barb. Never measured it,I will next time. Fill where the funnel is until fuel starts to dribble out the red circle.
Jeremy89
