1980 z28 rescue
She LOW!!!!!
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
I'm going to have to put the stock spindles back on or get new springs.
Why's that? Front looks good. Drop that ass.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
How bad? Slightly slimmer tire help out? I believe they make a few different style inner fenders for these cars.
Derick C.
Auburn WA
Derick
454/700r4
Well my drive way isn't flat and the car was in neutral, it should have rolled down the drive way.
I'm surprised the stock hood fits. It looked like even that foam Edelbrock filter was going to hit.
Derick C.
Auburn WA
Derick
454/700r4
It needed some trimming
Very nice! That's a slick setup with the '80-'81 scoop!
WFO
Texas Panhandle
Does it already have big block springs?
I put new big block springs on my 79, even though it had a small block, to get it up just enough to clear the tires.
It also made for better weight transfer to the rear for holeshots.
Derick C.
Auburn WA
Derick
454/700r4
I did not put big block springs in. I changed the spindles this morning so that's fixed. Now it doesn't want to go in gear when its running, doesn't seem to matter how much I adjust the clutch either.
idahovette
Weiser Idaho
Perry
K20-K10
Will it shift with the engine off?
Get every gear with the engine off. Might be a faulty throw out bearing.
I was thinking pilot bushing. If it's sticking, the input shaft will just want to keep spinning.
  • Like
Reactions: WFO
Derick C.
Auburn WA
Derick
454/700r4
I didn't even consider that. It's been many years since I've worked on anything with a manual transmission.
jturner
