1978 k10 radio patch panel
mtbadbob
Montana
Bob
V20
I am not sure I have ever seen one of those? I guess your going to have to hack out an intact dash and weld into yours?
No welding required, a rivet or 2 if desired is all.
mtbadbob
Montana
Bob
V20
I had the same problem. Fortunately I have a parts truck with the same color dash. So the dash from the parts truck was sliced and spliced into the build truck. A few pop rivets and once it was all back together you can't even tell it was cut.
Did the same, only I made sure I patched within the bezel area, shot some black foo-foo over the white patch panel & it's perfect, can't even tell!
scrap--metal
MN
Calvin
'85, '81
K10, K20
The previous owner cut the radio panel way to big for a newer radio. So I either need a patch panel or a whole new lower dash.
Here's what I did to fix the same issue earlier this year:
PO's hack job that I started with. Unfortunately the cut is visible beyond the bezel.
After the bezel was removed.
Repair section cut from a donor truck, which was already cut for a CD player. I got it for free, so I couldn't complain.
Here's the donor panel installed behind the lower dash in the truck. I did add a couple rivets after taking the picture.
I had cut this out of this scrap panel piece and sold to a member here , if seeing the shape and depression etc helps anyone
Here is the one I still have. I cant tell if that was factory that large or if that was cut wider by a PO(no idea what year the cab is or the last time it was owned by someone and used)
Bennyt
Surprise
Ben
Atomic Armadillo metal fab said he was going to produce that piece a few years ago. Not sure if we ever did or not but may be worth reaching out as not every is on the website.
mshawn
Malvern,Ar
Micah
c10,jimmy,k10
I'm having trouble find a radio patch panel for a 1978 k10. The previous owner cut the radio panel way to big for a newer radio. So I either need a patch panel or a whole new lower dash. My local junkyards have squarebodys but they all been gutted already. If someone could help me find what I need. Thank you
I made one that I’ll be doing a write up on very soon
NateP350
