1978 G20 with pictures (A SURVIVOR)
Preston
Mechanicsville VA
Preston
Good news the motor is not locked up, dumped my vacuum 2times cleaning acorn hulls up. The fun part now, I can set in the seat to check if the plugs are firing. I just put a new carb on my 85 might swap out the one I took off and see what happens.
Preston
Mechanicsville VA
Preston
Okay, if I were to unhook the fuel line from my fuel pump and run a hose to a 5 gal tank, problem there is a return line as well which line or do I put both lines in the 5 gal can just to bypass the tank temporarily. Thanks for your help
78C10BigTen
pennsylvannia
C10 BIG TEN
Im no expert but id personally put them both in
yevgenievich
Place
Name
Year
Model
Size
Good deal, looks pretty decent
Preston
Mechanicsville VA
Preston
I started washing it yesterday using a scotch brite and a lot of scrubbing this thing looks like a science project all kinds of stuff growing on it. Changed out the carburetor, distributor cap, rotor and spark plug wires late last night. Will see today if I can get it running.
Preston
Mechanicsville VA
Preston
Because this was a carpet cleaning van, they had put a spacer under the thermostat with a line going to a s/s tank behind the drivers seat with a return line going to a tee in the lower radiator hose I removed all the hoses and tank also there was a driveshaft connected to the place where the a/c compressor was with the clutch that turned it on and off, the shaft ran above the floor to just behind the seats that operated the vacuum pump. All that is coming out will flush the block and radiator today new thermostat and hoses and we should be ready to hit the road.
Preston
Mechanicsville VA
Preston
I have unbolted all the pumps and dohickies that wash carpet waiting for the PO to pick them up. Flushed the engine and radiator waiting for the hoses to get here too hot outside will have to wait until late this evening to put the parts back together. This van will loose about 500 lbs when I’m done. Will see I will keep you all posted, thanks for the help.
Preston
Mechanicsville VA
Preston
5 days ago I brought this 1978 G20 van home on my trailer, I had to winch the van on the trailer. No idea if it was any good, well it’s great after 10+ years setting it’s running and driving great, thanks for all the help.
From this not running
To this purring like a kitten
78C10BigTen
pennsylvannia
C10 BIG TEN
Sweet deal! If you want to toss those hub caps hut me up.
Doppleganger
OH-MI: Just like it sounds
Needs a bumper sticker or custom plate. At one time there was a law you had to have one of these....I swear its true. lol
78C10BigTen
pennsylvannia
C10 BIG TEN
No it needs one of these.... lol
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Great job, looks really good, big difference. Glad it worked out for you
crowe-t
