1973 K20 front D44 Spartan locker install
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
This is basically a pictorial R&R of a Spartan locker into my stock open diff D44 on the 73 K20. So...
Remove the tires, than all of the following will need to be removed: locking hub. disc brake calipers, bearing hub and finally the backing plate. As they are listed is how I removed them, this gets you to where you can remove the axles.
Craig Nedrow
Washington State
K10, K20, C20
Leave the locking hub together and remove it in one piece as less parts to keep track of. IE leave the wire retainer in.
Craig Nedrow
Washington State
K10, K20, C20
Than the c-clip will need to be removed.
Craig Nedrow
Washington State
K10, K20, C20
Next remove the outer nut, locking spacer, and inner nut. Inner nut has the pin that the spacer will locate on. I had to adj the nut slightly when installed to get the pin to align with the spacer hole.
Craig Nedrow
Washington State
K10, K20, C20
Next remove the calipers, takes a 3/8 hex. These will need to be pried off the disc.
Craig Nedrow
Washington State
K10, K20, C20
Now you can remove the six nuts that retain the backing plate
Craig Nedrow
Washington State
K10, K20, C20
Now you can remove the axles X2. This will allow differential removal.
Craig Nedrow
Washington State
K10, K20, C20
Once the diff cover is removed, mark the caps so they can be installed in the same position. Do NOT get this wrong!
Craig Nedrow
Washington State
K10, K20, C20
Once the caps are removed and numbered, and since I did not have a spreader, I used a couple pry bars and remove the carrier. It will come out with the front drag link left in. Carrier is a snug fit.
Craig Nedrow
Washington State
K10, K20, C20
Now on to the bench where the cross shaft pin needs to be removed. It is 1/4" and I had a long 1/4 inch drift so easy peezy.
Craig Nedrow
Washington State
K10, K20, C20
I always like to mark the ring gear in relation to the carrier so the gear can be installed in the same location. Just a chisel mark, here in line with the number 11.
Craig Nedrow
Washington State
K10, K20, C20
Now remove all the ring gear bolts, give the gear a smack or two with a dead blow too remove it from the carrier.
Craig Nedrow
Washington State
K10, K20, C20
Now the cross shaft pin can be removed, I used a socket that was the right od and some dead blow persuasion. pushed out with smooth tension like a hydraulic cylinder.
Craig Nedrow
Washington State
K10, K20, C20
Here are the parts. The instruction book is excellent, and the kit included a new cross shaft, and shaft retaining pin, (it is a spring pin.)
Craig Nedrow
Washington State
K10, K20, C20
Once the cross pin has been removed, the original spider gears and shims can be removed. None of these parts will be used again. but I saved them in case.....
Twistedwhisky
