- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I never thought I'd consider such a thing, but now I am and I'll explain why.
Remember I have this 10 bolt front axle with the Air Locker and 4.10 gears? I was going to convert it to an 8 lug front and use my 14b Full Float 4.10 rear axle with it. Turns out, my 4.10 axle is a 3.73 which is great. I'm using in one of the 2wd trucks now.
So to get off cheap as possible. I'm now thinking of install the 10 bolt Air Locker 4.10 front just as is with 6 lug hubs. I have 2 good Semi Float rear axles with 4.10 gears that I can throw a Lock Right into for cheap. So it's still going to be a half ton truck, but how about getting 6 lug axles for this 14b Semi Floater??? I know they exist in GMT 400 trucks, but I hear the length is different and they don't interchange with a Squarebody Semi Float. Would it be possible, or is there enough meat left to have the current axles redrilled for the 6 lug pattern, or is it possible to buy 6 lug axles for the Semi Float?
Basically, I'd rather have an updgraded half ton using the SF rear axle, than a downgraded 3/4 ton. I just think keeping the 6 lug will be much cheaper cuz then I could keep my 6 lug wheels that I like, and tires in a 15in size are always cheaper, abundant and sky is the limit in sizes. Makes sense or is there any other suggestions???
