Silver Square
- Jun 9, 2024
- Fayetteville, GA
- Jason
- Sierra Grande 15
Has anybody ever put on the 1" ORD body lift kit? If so, did you need to modify anything to make it work? fan shroud, radiator hoses, steering column, shift linkage, etc...? They are made from aluminum. I've heard that direct contact between aluminum and steel can cause corrosion because of the dissimilar metals reacting with one another. Any problems with that? Would I be better off with hockey pucks?
I've seen several posts on various forums that a 1" body lift actually makes the bumpers sit nicer on the trucks, and can help with additiional clearance when working on the truck. Any Thoughts?
I'm just a bit concerned that when I get my 35x12.50 boggers I may end up with clearance issues. It looks like they actually measure 35.4" tall and have a 13.2" CS. Most tires tend to run smaller than advertised, but these seem to run larger. I have a 4" BDS spring lift on my '77 K15.
