Sear's Craftsman Handi Cut Cutter
Larry Thomason
clinton, Ok
Larry Thomason
R 1500 C1500, C2500
Awesome cutter for Body side moldings, Vinyl over door strikers vacuum radiator heater hoses nice straight cut! Just wanted to share if you hadn't tried it!
What @Snoots is hinting at, we need pictures!!!
I vaguely remember the Craftsman Handi Cut name. Was this back in the 90's when Bob Vila was doing the commercials? About the time of the Robo Grips?
Bennyt
Surprise
Ben
I have one. Works well. Use it mainly for cutting hoses. Sold under several brands. Replacement blades available on Amazon.
I have no idea what it is.
I use a hose cutter:
I have both. Mine straight blade cutter is not craftsman though and it's compound leverage,if you're not careful you could lose a finger.
Turbo4whl
Downingtown, PA
Wayne
I have both. Mine straight blade cutter is not craftsman though abd it's compound leverage,if you're not careful you could lose a finger.
I also have a ratcheting cutter. Yes, it will cut anything but steel. I use it for battery cables, 2-0 and 4-0 on the medium duty trucks.
cmcqueen
