82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I waited on mine for almost 7 months, was nerve wracking but the end result was stunning, and wait was worth it!
When i was 15 I got my first square. It was a 75 GMC 3/4 ton longbed for 500 bucks. Me and my dad replaced everything but cab and hood because it was rusted to ****. The bed looked like Swiss cheese. You could see the street through the bottom of it. It was summer time and right before school started he sent it to his buddies paint shop. It was in there for 10 weeks.
I was beside myself waiting for it to come back. I was telling my friends about it. They started calling me a liar and that I didn't have a truck at all. Finally got it back and they did a great job on paint and interior.
After about a week or two of driving it to school, I came out to go home and some d!ck keyed it all the way down the right side from bumper to bumper. I was so pissed!
Sad Sack
Omaha, NE
Goober
C15
dikheads are everywhere and now there's a whole new level of stupid dikheads out there, it's so bad it's scary.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
After the OBD1 TBI torx adjust to get the idle down the truck will take a long crank on ignition before turning over but then will run great. After first ignition and it has been driving it cranks up normal. It idles high for about 3 or 4 seconds then drops down to a good sounding idle, and immediately the service engine light comes on.
17 second clip. You can hear it then see the light.
I am currently out of town but wanted to post this and get some feedback. I am planning to get the paper clip back in to OBD1 and adjust more when back with the truck either tomorrow or Sunday afternoon.
mxer147
Colorado
Jack
k20
Impatient as usual, so I went for it since I really want to get this back together because I have parts spilled all around my property. I still need to paint a little under the hood so I am leaving the paper until that’s completed. I had this paint leftover from the z28 project 30 years ago. This blue looked awesome on that car. The blue stripes look okay for my 20 footer.
Z28 Guy
mississippi
Jermaine
Auto Zone etc offer 3 different versions of a AC delco plug.
There are NGK plugs that are shorter than those "header" plugs for a small block anyhow, should be the same for a big block I'd think.
Last time I bought any, there were Accel shorty plugs and standard length plugs too. I've run a few sets of the Accel 576S plugs and they are definitely a short plug. No performance or durability complaints from me, they work well with a GM HEI.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Looks good to me.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Ok got the tach hooked up and mocked up to the steering column with zip ties. Lol
Heat shrink solder and for the wires to the dizzy.
Ok now I need some ideas on the mount to the steering column. Hence the zip ties. I would use a hose clamp but the box around the turn signal handle prevents that.
Can I run a self tapping screw on that hole into the column? I was afraid I might hit something. Of course I won't use a long one but, I was thinking of using some double sided tape I have that is super good. Then run a screw in it to add extra hold power. Or if not maybe tape and zip ties. Doesn't have to be perfect just not Jerry rigged. Any ideas would be appreciated. Y'all might think of something I'm not.
Man I'm getting old. Doing this i got muscle cramps in my back, hip and legs. Burned my forearm on the heat gun too. Haha I had to stop a couple of times to let the cramp go away. Couple of times I was in the right spot and it was so bad I had to get outta that position and let it go away. Lol
But I got it done! :peace:
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Big shout out to @TotalyHucked Zach!! He hooked up some cool stickers for the new back window. So many to choose from.
Thanks again Huck!
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
My 93 cranks for a good 2-3 seconds before it fires on first start after cold and sitting.
That should be because the fuel pump is sent power when it gets oil pressure on startup. Why a hot start will start faster.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
I have some really good double sided tape too, I would trust it to hold a tach. Get a fatter ziptie and call it good. I probably wouldnt run a self tapper in it.
Manual columns are way easier to mount a tach on! Two big zipties and that's good enough and non invasive.
You have another problem and the oil pressure switch is masking it. The oil pressure switch is a redundant source of power for the fuel pump,so in case of a failure in the pump relay the pump circuit the op switch takes over so you aren't stranded on the road. The fuel pump relay should be the source of fuel pump power starting or running.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
You have another problem and the oil pressure switch is masking it. The oil pressure switch is a redundant source of power for the fuel pump,so in case of a failure in the pump relay the pump circuit takes over so you aren't stranded on the road. The fuel pump relay should be the source of fuel pump power starting or running.
I ain't worried about it. 3 seconds cranking max. Don't mind a little oil pressure getting built up before firing. It's always been that way and runs great, 200,000 on it. It's also not that much slower than hot starts.
WFarm
Central Virginia
K5 Blazer
Drove down to Chatham VA for their monthly Cruise In, which are typically huge. Tonight the turnout was heavy due to the perfect weather, estimates were at least 500 cars attended! But only 1 awesome Blazer.
It’s about a 45 minute ride each way, and the Blazer did wonderful, no problems at all. Transmission temp climbed up to its “Happy Temp” of 165-170 and stayed there. Even my co-pilot (aka The Wife!) commented about the great ride.
Check out the pup made up to resemble a Giraffe! I was embarrassed for it but that was one happy dog.
jbwhitford
