REDS NECK REPARES!~
Why not just pinch off the line?
If you clip a nail down to a short capital Tee. You can slip the stem of the Tee in a brake line,put the line back in the wheel cylinder and tighten. The nail head blocks the end of the line,so you don't have to repair a line later.
Sad Sack
Omaha, NE
Goober
C15
Just disconnect rear brakes master cylinder line and put a plug-in till ready to fix and pray the front brakes do their job right. And as Edelbrock stated (good catch by the way), drain that chamber completely first before plugging it.
Edelbrock
Earth
Grumba
K5 Blazer
That's not a bad idea, but you would have to drain the fluid from that chamber or the plug would blow out. But ya, that would work.
I'm curious about that nail idea. Could it damage the cone on the slave cylinder? Although I guess that would not matter, since it would be replaced during the brake job anyway.
I'm curious about that nail idea. Could it damage the cone on the slave cullender? Although I guess that would not matter, since it would be replaced during the brake job anyway.
No damage on my VW Fox to get home from Independence MO. It was truly a jam and a very quick temporary fix to get home when I blew out a wheel cylinder. I did the same thing to a neighbors Ford Ranger,as a quick fix to get him home,I wasn't there when Hunters Dad did the correct repair,but I never heard anything good or bad. As for lighting shoes on fire,not really recommended,but I needed shoes that night 8pm ish no way to get new shoes,so that's what I did. Never did change them after. But these were legitimate use what you have,not much option deals. Not I have days to play on the internet and contemplate how to not fix my vehicle correctly. The Fox I did in a hardware store parking lot,where I bought the nail 100 yards from where I lost my brakes.
Edelbrock
Earth
Grumba
K5 Blazer
No damage on my VW Fox to get home from Independence MO. It was truly a jam and a very quick temporary fix to get home when I blew out a wheel cylinder. I did the same thing to a neighbors Ford Ranger,as a quick fix to get him home,I wasn't there when Hunters Dad did the correct repair,but I never heard anything good or bad. As for lighting shoes on fire,not really recommended,but I needed shoes that night 8pm ish no way to get new shoes,so that's what I did. Never did change them after. But these were legitimateuse what you have,not much option deals. Not I have days to play on the internet and contemplate how to not fix my vehicle correctly. The Fox I did in a hardware store parking lot,where I bought the nail 100 yards from where I lost my brakes.
The nail is an imitative idea. So you remove the brake line from the wheel cylinder, install a shortened nail into the brake line, and then reinstall the bake line. That's all there is to it?
That's what I did.
What is your giant reluctance to just fix your axle seals and keep your brakes functioning as intended. Rear axle seals are really NBD at all. Remove the diff cover. You need to change fluid anyway. Remove the cross pin retainer bolt,and cross pin. Push in on the axle pull the c clip Remove the axle. Several methods of removing the seal which is no big deal. Drive in the new seal,push in the axle,replace c clips,cross pin and retainer bolt. Reseal and refill the pumpkin. This is beginner stuff. And way better than rigging brakes on a lifted truck with stiff springs. Yes weight transfer comes into play too. Just remember to heat the cross pin bolt with propane before trying to loosen it. And to any of you that said you need to drain the mastercyinder if you block the rear line at the master. BS. no you don't. You may trip the combination valve though,which you would anyway with no hydraulic pressure.
Edelbrock
Earth
Grumba
K5 Blazer
Swapping axles soon, no desire to repair this one properly. Just want a bandaid get me by.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Speedi Sleeve on the old axle? Reuse the old seal ? Seems like a lot of work for a bandaid but not sure how to beat a leak without a reseal. I guess no one makes a diff stop leak product. :anitoof:
Edelbrock
Earth
Grumba
K5 Blazer
For a stop leak, they do make this - and its a fantastic product that usually works very well. But not in this case.
  • ATP-Automotive-AT-205-Re-Seal-Automatic-Transmission-Fluids-8-oz_a5a9b46c-127d-4948-94bd-a406...jpeg
I've said it before and I'm sure I'll say it again. You sir, are a genius.
Camar068
10 yrs Air Force
Here in KY, most people that think like the original post, aren't driving their vehicle more than 5 miles a day and barely touch the throttle or brake. They also most likely don't have plates or insurance and are going out for the local/federal hand out.
Turbo4whl
Downingtown, PA
Wayne
Some these fixes may work in a, "get the vehicle home scenario." All of these temporary fixes will only aid in making your truck look like the picture in your avatar.
My suggestion is get a rental or borrow a vehicle until you fix your truck.
Since I explained how a GM dual piston master cylinder works to many times, just know jury fixing a brake system is not a good plan.
meizy
