Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Swaybar mount on. My poor OE bushing got squished by the wrong mount. :eek:
Hopefully it will regenerate it's shape :cool:
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Finally got 99% of the paint stripped off the grill. Whata pita! So taped it off and sprayed two coats. Tomorrow I'll flip it over and give it a couple of more.
Doppleganger
OH-MI: Just like it sounds
Project Millstone lingers on. Having the back of the doors blasted. I stripped the fronts - blaster will dust the fronts to clean them up 100% and make a perfect base for epoxy primer. Its far cheaper this way.
Weird thing......figured the doors were all brown and they painted beige at the bottom for 2-tone. While stripping the doors I found they were actually all beige and they painted 3/4 of the door brown to cover for 2-tone. wtf?
Also skim coated the roof - it had very minor issues.
legopnuematic
Licensed Junk Dealer
MO
Spencer
That's how two tone squares were painted. Secondary color shot first, masked off with butcher paper then primary color sprayed.
legopnuematic
MO
Spencer
Brought a laptop with a DVD drive to the shop and some shows/movies to rewatch while I worked
Got the back of the cab hit with some high build epoxy primer.
Camar068
10 yrs Air Force
@JamesSam it’s a start! I hear you on the pollen, it’s going nuts here too.
Got some projects in the mail from Summit. Vacuum gauge, and a set of Bilsteins for the front. The KYB gas-a-just feel good until hit a big bump or dip, then they give up and the front end oscillates all over the place. Which feels dangerous on the freeway at 65.
What location did you put the gauge?
Camar068
10 yrs Air Force
ordered a replacement belt for my LS swap as it was cracking (2006 LM7). Anyway the belt called for 96". What I used was 93" when I did the swap. Returning it and the correct one will be here tomorrow. Future reference for me. LM7 belt 93". Continental and Gates 6 rib. Also ordered the tensioner.
Z28 Guy
mississippi
Jermaine
I need your help guys. I pulled my old injectors out to fast and didnt pay attention to the injector hole placement. My truck is a 87 model 454 TBI if that matters. Do anybody know EXACTLY how the hole in the injector hole lines up or better yet have a detailed pic.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Watch at the 6:54 - 7:05 time-frame.
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
eymerlos100
