BBC 396 wil not idle with any carb
Beast496
Northern Nevada
Ron
Sierra K3500
Not sure on what you mean square up transfer slots.
They are the slits in the butterfly valve bores, visible from below, they should make a square as a baseline for tuning. Atleast, thats the way i was taught.
Rustisbest
Tennessee
6.1762844 liters
Make sure you're plug wires are on in the right order.
In the 1st pic you're choke isn't wired up so it's gonna flood fairly quick since its gonna stay fully closed.
Looks like you're vacuum hose for the advance is hooked up to the metering block which is ported vacuum. Put it on manifold. Should the fitting on the left of the baseplate.
4 corner idle mixture screws baseline is 3/4 turn out
2 corner is 1 1/2
legopnuematic
Licensed Junk Dealer
MO
Spencer
@Beast496 beat me to it
If the transfer slots are over exposed, by the butterfly being open too far, it will be running off of the transition circuit not the idle circuit, which will render the mixture screws basically useless.
An engine will run with them over exposed, but will display poor tuning attributes. Lack of responsiveness to adjustments. An easy way to get an idea it the butterfly if open too far is if you have a vacuum signal at idle on a ported vacuum port. If it’s idling on the idle circuit there will be no vacuum to a ported source at idle. If it’s idling on the transition circuit there will be vacuum at a ported source at idle.
If you have a poor intake gasket seal (large vacuum leak), it will show on a vacuum gauge. Doesn’t have to be idling to check, if the needle bounces from 12-20lbs (this number depends on what vacuum the engine will make, it will vary) to zero being held at a constant rpm there’s some sealing issue, as it’s drawing air through the leak rather than the carb, thus the loss of vacuum signal.
What is known about this engine? You mention it has .03 over pistons, so it’s been over bored, and presumably decked. If it has been decked, there is a potential there is an angular stack up that might promote poor intake sealing, or it the China walls were not machined the intake could be held up by them preventing a proper seal. Lot of potentials here.
Adriank
dallas
Adrian
Gmc Sierra long bed
2 corner is 1 1/2
I did not know that on the 4 corner mixing screws. Thanks! Since that picture was take i have moved the vaccum to manifold. That particular carb which is on that picture has had everything on the choke removed. Thats why i it wasnt wired up.
Adriank
dallas
Adrian
Gmc Sierra long bed
Set your shop vac hoses to blow,put an air cleaner with a snorkel on the carbureator,put rags in the exhaust pipes, pot your shop vac hose on the snorkel and tape it up,turn on the shop vac and start spraying everything with soapy water look for bubbles.Alternately you can blow in the exhaust and seal off the top of the carbureator.
I will have to try this weekend
Adriank
dallas
Adrian
Gmc Sierra long bed
Ok thank you i will have to check this.
No vacuum leaks that i can tell with carb cleaner. Pcv valve is new and new grommets. Same with dipstick everything seems to be completely sealed off. Only vacuums on carb is to vacuum secondary which is new hose and to turbo 400 which is new as well. Compression is spectacular on all cylinders. Do not remember the numbers off top of my head though.
Go back and read carefully what I said about the dipstick,vacuum gauge etc. I'm trying to determine if you have a vacuum leak under the manifold a vacuum gauge on the dipstick tube with all other openings plugged will show this.
Adriank
dallas
Adrian
Gmc Sierra long bed
Go back and read carefully what I said about the dipstick vacuum gauge etc. I'm trying to determine if you have a vacuum leak under the manifold a vacuum gauge on the dipstick tube with all other openi gs plugged will show this.
Ok will do. Going to check on this weekend and will be back with update
cadillac_al
Maine
Alan
Is that an HEI ignition or points?
GTX63
Tennessee
Ty
I recently pick up a motor from a guy that owns a shop and did a engine swap on a car. He didnt know much about the motor besides it ran and drove to his shop.
I'm just going back to the early part of your first post because from experience, I've resolved a lot of issues by backtracking to the simple and the obvious.
Just on it's face it seems odd that a guy would pull such a motor with no knowledge of its condition other than it was able to pull the vehicle through his bay doors.
Did he not have any discussions with the previous owner or ask any questions? A running 396 by itself is a conversation starter. What reason did he have for pulling the motor? How long has it been sitting?
I mean no disrespect; I'm just pointing out that there may be more to the story back at this guy's shop.
Sad Sack
Omaha, NE
Goober
C15
I think understanding and getting to know the engines cam should be paramount.
Then start over, with the attitude that you are putting an engine together.
Too many unknowns, like was it built for racing, towing, expected RPM range, it looks like it has roller rockers, obvious stuff is the bored .030 over and RPM heads, what year block is it, correct spark plugs, valve lash set, degree the cam, reseat the manifold. If had acquired an engine in this manner I would try to understand as much of it as possible before installing - not after. Worse case, take it apart to know what it was built with.
Adriank
dallas
Adrian
Gmc Sierra long bed
I hear you and totally understand. The guy i got it from is a die hard LS guy his shop specializes in LS swaps. The costumer which the motor came from. It was in a 1968 camaro. The customer wanted a new turbo LS installed in his car. Cause he want be able to cruise it and have more power at the same time. The shop owner which i know personally took the motor as a down payment for some of the work that was getting done. But the owner is a computer wizz. Put a carb infront of him he wouldnt know what to do. Which seems to be my case at the moment oddly cause ive never had this issue.
You still need to verify compression and vacuum if one or the other is off,everything else is a waste of time.
Hard
