Sea Foam
Mango
JacksonWyoming
Gil
Does anyone here use Sea Foam in their fuel on a High Milage 350 TBI ?
I found the post on sea foam, not going down that road
gmbellew
Kansas city
glen
suburban 1500
I've been trying to clean the carbon out of my 350 TBI engine, because i think it is the cause of a random miss at idle and occassional missing under light load.
I've been doing a pretty steady diet of Redline SI-1 in a maintenance dose for the last few months and used AC Delco top end engine cleaner before my last oil change. I plan to keep at the Redline until the next oil change and also use the AC Delco top end engine cleaner before I change the oil next time and evaluate where things are after that. I have also been using seafoam in the crank case for 300miles before oil changes for the last couple oil changes to help clean up any sludge in the engine.
chevytech87
Tomball, TX
Brandon
GMC R1500
I’ve seen the delco top engine cleaner do incredible things on many engines, especially the new direct injected stuff. I run the Lucas fuel injector stuff in all of my vehicles, never had problems seems to do it’s job. I’ve only seen sea foam cause problems in small engines when I used to repair those, and usually it comes down to operator error. Often times people put wayyyyy too much in a system, which I’m sure you can do with any of these products. But overall it seems to be a preference thing.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Even when I run WAYYY too heavy of a mixture (we're talking like half a can in the gas tank of an 8hp briggs and stratton), the thing bogs down and chugs, but then runs GREAT afterwards, cleans it right out. I've never seen any damage done from the stuff, not even sure how it could damage anything?
Camar068
10 yrs Air Force
I put 2 caps of it in my early 2000's weed eater (about 20 yrs old). It wouldn't crank before or wouldn't stay running. After the sea foam, I thought it was literally going to blow up it was so responsive. I proceeded to whack the weeds as fast as I could lol.
Sea foam....love it.
Carb'ed Vortec 350
I've never used sea foam, but I used Motor-Purr all the time. Unfortunately Motor-Purr is hard to find. I am lucky and my auto parts store carries it.
Shorty81
Baby Boomer
North West ohio
Darren
I use Star Tron. It work great for water separation in that junk ethanol that our government shoved down our throats.
bft305
ME
Ben
I use B-12 chemtool it is great stuff and works awesome! Plus it is cheaper than sea foam
Catbox
Peter
C20 Silverado Camper Special
I am running Sea Foam High Mileage right now in my TBI Suburban.
It has been idling wicked rough during the warmup cycle for about 45 seconds then is smooths right out.
After Sea Foam it tends to clean up quite well.
This time though, I have ordered a set of new AC Delco sensors for the thing.
It has 250k on the clock, so they should help it continue to be happy.
Mango
JacksonWyoming
Gil
@Catbox, Sweet What Sensors are you Replacing
I have 189,000 and runs pretty good like to keep it that way
Going to pull teh plugs and check them out only about 10,000 miles on the new ones
Catbox
Peter
It throws a MAP sensor code.
We in haste, replaced it with a house brand sensor and it got worse.
I have ordered AC Delco brand sensors for it and that should in theory stop that issue.
I figured changing the other ones would be good for it in general as well.
Here are the pieces that are on the way to me:
Manifold Pressure (MAP) Sensor
ACDELCO 2133205 (Daily Driver) Professional Info
EGR Valve Control Solenoid / Motor
STANDARD MOTOR PRODUCTS VS12T T-Series Info
Throttle Position Sensor (TPS)
ACDELCO 19322821 (Daily Driver) Gold Info
Like with always though, I am not throwing the OG parts away.
They will be place into the boxes the new parts come in and put into the back of the burb.
1976dully
Kansas City MO
C30
Use the stuff in everything we have. Dumped some in our '48 Farmall Cub after we did an extensive cosmetic restoration. Crap flew out of the stack like you wouldn't believe!
SirRobyn0
I've used it yes, but it's not my favorite product. If your looking for a product to apply directly to the carburetor I like ACDelco X-66A The ultimate in direct decarbonization is X-66A followed by 8oz of water slowly drizzled into the carburetor at 1,500RPM. If your looking for a pour into the fuel tank, I've done seafoam, but I certainly don't swear by it.
Jleopard77
