Rust coating for fill neck
GorillaHumper
Belmont nc
Bj
K10 short bed manual
My filler neck had a ton of rust in it. I scrubbed what I could out with a rust solvent and dryer vent brush on a drill. Is there a coating I can use on the inside to keep trash from going into my new tank?
fast 99
Spokane, Washington
There is a commercial zinc dipping company here that will do small jobs. Items are dipped in rust remover [acid] first then plated. Might try one local to you.
or Por 15?
Old Guy Bill
KY
Bill
Id think you could just replace it for the same cost…
I'd clean it and epoxy prime it.
good to note that any epoxy coating will need to be gasoline resistant and it will have to cure
Appliance epoxy from rustoleum says about a month, and i dont know if its gas resistant but just a random epoxy i read the can on
Auburn, Washington
There are many coatings advertised to seal the inside of gas tanks. Any of those would work fine, considering the filler neck only sees occasional soaking with gasoline.
Epoxy primer or any quality urethane 2k paint is also quite solvent proof.
Or replace the filler if you can’t get the rust sufficiently removed and cleaned inside the filler.
cadillac_al
Maine
Alan
The thing that scares me about epoxy primer is that I painted the underside of my truck bed with epoxy primer and it is peeling off in sheets. I would hate to have that kind of problem inside the fuel fill area. I have had good results with epoxy primer in other areas but if you have a screw up it could get flaky.
probably wasnt prepared right or something was caught between it
What chemicals were on the surface?
ali_c20
Austria
Alexander
C20, K5
Get a new filler neck, no worries about prep, paint and less work.
kains77
