squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Besides the fact that the seal is cooked. Hard to tell, is it coming out crooked?
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Stuck piston. Couldn't even force it open to get it off the rotor without pulling the banjo bolt. DOT3 bursted forth out the banjo hole. Then it came off. About 1/3 of the rubber piston seal was just gone. Got the truck in November, not sure how long it was this way, but it still stopped. Felt like the 350 was fighting the brakes every time I drove it however. :hahano:
Camar068
Air Force Supporting Member
10 yrs Air Force
just got some from autozone for $26/each....cool thing is they are painted now....Duralast.
squaredeal91
Greg bush
1991 SB
Picked these up today. Heard a while back that as of this year they are no longer printing books?
410 John
HdG, Maryland
350 4bbl 4 speed
Painting one wheel, so far. Back to silver. It’s supposed to rain. My Father had these matching the body color and modified a spinner/knock off cap to cover the lugs. As seen in my avatar. Not my choice of look.
84-C20
Chevrolet
Well I hauled chicken manure away from the farm last weekend and it was gross inside and out. I drove it all week to the shop thinking I'd have to clean it up, but instead I spent my free time Tuesday and Wednesday after work fixing a headlight issue. I think what happened was the ground wire came loose from the connector on the right headlight. This caused high resistance and burned up the ground connector on both the headlights.
So I ordered new connectors and soldered them in.
For anyone interested I used Dorman P/N 84790.
So today I took time to do some of the clean up after work, next post will be that since I want to post pictures.
84-C20
Chevrolet
Finally got to do most of the clean up of the truck today, after manure hauling last weekend.
Below Before:
After:
Still need to do the interior, and under hood. If not tomorrow then on the weekend.
Also need to replace the starter this weekend, and whenever we get a dry spell I need to fix the tears in the bedliner..... Again!
SK 99
Marysville, OH
Steve
K15
Didn't do anything today other than drive it.....
alex7915
