JM in KY
- Oct 27, 2022
- Lexington, KY
- John
- Sierra Classic
What’s the best way to remove the steering stabilizer on a stock V1500? The end closest to the front wheel is stuck solid. I know the bolt that goes through the long tie rod is tapered, which is probably part of the problem. I’ve banged on it with a hammer and heated it some with a torch. What’s next? Wheel puller of some kind?
