Dent removal
84GMCSierra
Central Arizona
C2500
What would be the best way to get out this dent in the side of my bed? I have tried from behind, but no luck due to the gas tank being in the way, and I've tried 2 different suction cup pullers, but they wont "stick" to the metal. I'm thinking I have to lift the bed, or remove it, as I need to replace the front panel as well. Hope you can see the dent. It's just in front of the filler door
ChuckN
Bellinham, WA
Chad
Maybe take a picture from the opposite angle, looking from rear to front to help with the glare.
I had one in the same exact spot. I himmed and hawed about it, then decided to get a paintless dent removal guy I know to give me a consult. Glad I did. He took the job reluctantly, and he had to drill a small hole in the wheel well to get a bar in there to move it back out. He said that the metal on these things are much tougher than modern vehicles, and it was a hard job for him. Even now it’s probably 95% there, not perfect. But he did a tremendous job on it, and he was out in my garage for over a couple hours.
But I’m not super experienced with body work so take it with a grain of salt. I do know this guy personally and trust his opinion when he says it wasn’t an easy job, since he’s worked on many other vehicles of mine and is a go-to guy for the local dealerships here.
1STLS1
West Phoenix AZ
MIchael
This is a video where a guy uses several glue sticks and a propane torch to heat them to pull a dent, fast forward to 2:30 where he actually does something. I also purchased a cheap PDR kit from Amazon with a glue gun and have had great success with it also. Just take your time, it all doesn't come out at once.
As an Amazon Associate we earn from qualifying purchases.
Jleopard77
