85 GMC crew cab
dbush
Cheyenne, Wy
Dave
GMC K2500
Welcome from Wyoming!
Corvette Ed
East Tennessee
Eli
Welcome to the forum from East Tennessee.
Babs
Ottawa Valley
Chevrolet CUCV
oldretiredafguy
N. Texas
1988, 1988, 1991, 1983
350, 350, 350, 350
Welcome to the forum from N. Texas!
You're gonna hate that POS 4 & 7 way hitch plug. You can't use them both simultaneously. I got rid of mine (after breaking off both covers) with a Hopkins combo connector like this one:
Bennyt
Surprise
Ben
I'm not following...how would you use them simultaneously?
oldretiredafguy
N. Texas
350, 350, 350, 350
While pulling my car hauler with a '75 1/2 ton on it, an eighteen wheeler lost a tire tread. Didn't see it in time to swerve, and it bounced up and cut the wiring under the trailer, losing the turn signals/brake lights on the rear of the trailer. Had to keep the 7 way plugged in for the trailer brakes, but still needed turn and brake lights. Bought one of the magnetic light sets, which uses a flat four way. The way some idiot designed the plug, you can't open both covers simultaneously.
Washington
Nice rig! Old highway dept truck it looks like.
Like what you did with the ashtray as a mount for all the switches and charger. That’s clean.
akchevrolet
Andrew
I like it. I'll trade you my single cab for it haha. Nice truck there.
Meatwad
North Georgia
Ryan
C2500
Update. The th400 started leaking pretty bad from the bell housing, instead of pulling it apart, I pulled it out, sold the 350/th400. Got a smoking deal on a complete 2003 8.1 and allison for the same price I sold the 350 for. Cleaned the front of the truck, got rid of the surface rust, waiting for a dry day outside to primer and paint the bare metal areas. I removed the unnecessary wires from the engine bay and labelled the wires.
:welcome:
Meatwad
North Georgia
Ryan
C2500
Went through he 8.1. Cleaned it up, new gaskets, new water pump, new PS pump, long tube headers, new starter, etc. Cleaned up the frame. Went through the wiring harness and removed unnecessary pins and cleaned up the harness. I'll be moving the battery to the driver's side. Cut the trans tunnel out before placing in the engine and trans. People say there is a boss that needs to be ground down, however I had no issue with putting the SBC mounts on. I did have to tap 2 holes on driver side of the engine where the mounts bolt up to. Converted the cam sensor to the 2004+ sensor with cover and new timing chain and sprockets. Wires ran for the alternator, battery, and for the wires running into he cab. Still have some of trucks harness to clean up. I ordered Dakota Digital HDX gauges. Working on modifying the stock trans cross member. The stock 8.1 PS pressure hose fit perfectly
Meatwad
North Georgia
Ryan
C2500
More pictures
cbass91120
