New here.. NW Ohio 86' Sierra Classic
SquareUp
NW Ohio
Jordan
2500 Sierra Classic
5.7 vin M
Hey all!!
I'm from NW Ohio. Sporting a Clean 1986 GMC Sierra Classic. 66,000 originial miles.
I am currently rebuilding the motor due to a worn valve guide and a leaking main seal. This is my first square body, and I'm looking forward to making it bad ass.. Upgrading horses, torque, and height. haha
Currently sitting on stock suspension, with the motor pulled.. Starting to break down the motor this week.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome: Cool start.
Craig 85
Nashville, TN
454/TH-400/NP205
Welcome.
Moderator Administrator
:welcome:
animal
Moderator
Lee
c10 silverado
350ish
:welcome:
SquareUp
NW Ohio
Jordan
2500 Sierra Classic
5.7 vin M
Bad news... valve guide is bad... block is scored really bad in number 6 with a lot of wear on the rest... new a new power plant.. any suggestions.. $1500 budget...
Moderator
Howdy!
That sounds like very abnormal wear for only 66k. But you should be able to pull off a stock overhaul and keep it within the budget.
SquareUp
NW Ohio
Jordan
2500 Sierra Classic
5.7 vin M
Yeah.. I Agree. I'm not sure if the block is salvageable..
Here is a picture of the cylinder wall
Moderator
Woah, that's a gouge for sure.
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
Welcome, good looking truck. I wouldn't mind rebuilding an engine for a rig in that condition. A machinist can tell you quick if that can be fixed. .030 overbore may be all it needs. Head work, pistons and the rest of the goodies are reasonably priced if you build it yourself but you are still at the cost range of a crate unit. I prefer to build my own. Good luck!
SquareUp
NW Ohio
Jordan
2500 Sierra Classic
5.7 vin M
I am very much on the fence.. This truck is spotless underneath as well. I will get some more pictures up as soon as i can. But I want to keep the original motor and trans with the truck and make this a full restore since it is in such good shape.
Downside.. I'm very new to this stuff..
WFO
Texas Panhandle
1973c10
Don
Welcome aboard
hauto85
