Water mist cooling and an easy up ???
Okay I've never used a water mist system, but I have an easy up just was wondering would putting a mist system around the easy up and working outdoors on record heat days be a good idea. IDK will my clothes get all wet, my tools etc. Anyone with experience? The good the bad? Has anyone improvised one so I don't have to wait on shipping.Supposed to have record heat the next few days and I have stuff that has to get done.Hoping to do something today not waiting on shipping. If I have to order the Walmart one, thinking I'll do 5 feet on each side and 10 feet on one end of the easy up, pull the front end under it.
78C10BigTen
pennsylvannia
C10 BIG TEN
I imagine yes everythimg will get wet to some degree... i have used an easy up at work over our machine during satans tryin to kill you heat and other then shade it didnt help. Granted we didnt use a mister but we had the engine wide open so wouldnta been a good idea
Finkaire
Finkaire
California
Loren
Silverado c10
They work great, just don’t expose to bare metal. Additionally buying from Walmart, if you don’t like it you can return it
The Right side of Washington
Misters don’t provide near as much cooling if it’s humid out. It’s the evaporation rate that make misters / swamp coolers effective.
Being in KS iirc, you may not see the best effect.
That’s why you only see swamp coolers where the humidity is very low when it’s hot out.
The least of your worries is anything getting wet imo, short of having the heads off an engine maybe. If it’s record temps it’ll dry perty quick just not as quick as if humidity was really low.
Hunter79764
Grand Prairie, TX
Suburban V20
If your humidity is much over 50%, the benefit is going to decrease pretty quick. You might find yourself pulsing it on and off to some extent so that you don't just end up with everything wet.
One thing to note, higher water pressure is going to give you much better performance. Low pressure and you will get bigger droplets that just coat everything. Higher pressure will get more atomization and more cooling. At one point, I had one with a dedicated booster pump that worked better, but with Dallas humidity it wasn't great. When a dog chewed the hose, I gave up. But in West Texas, in the dry, they work great.
Bennyt
Surprise
Ben
For those of you considering it...the commercial systems use pumps to significantly increase the pressure which atomizes the water. For a decent size porch, plan on $1-2k minimum. These systems work incredibly well and help with bug control. Again, it depends on the humidity. For the system i wanted, i estimated about $5k with copper tubing and the good nozzles.
The systems sold at WM/ HD dont fully atomize the water and you will get wet.
Bennyt
Surprise
Ben
At first I thought you were going to spray the radiator to get more heat transfer.....
PAW used to sell systems for automotive use in the 80's for this purpose as well as systems that sprayed into the intake tract to reduce detonation. I heard that they worked quite well but were discontinued as stuck pumps, bad installs, etc would damage too many engines.
I remember in the late 90's a lot of guys in restricted classes of racing had Nitrous spraying on intakes and radiators to cool.
Hunter79764
Grand Prairie, TX
Suburban V20
I remember seeing an early Hot Rod Drag Week write up where some guys were running a stupid fast turbo 4 cyl Fox body, hauling a small trailer with slicks and kegs from their local brewery/sponsor. It blew a head gasket but they needed to get to the next stop to stay in the running, so they took a keg that they emptied the night before, and refilled with icewater instead of beer, pressurized it with their CO2 tank and ran a tube to a sprayer on the radiator. The passenger was watching the temp gauge, and would pulse the valve to spray water directly on the radiator to keep it limping along, then tore it down and threw a head gasket on it the next hotel parking lot. Gotta love the heroic patches like that.
But yeah, shade is good. Airflow is good. Misters are a mixed bag...
hauto85
