WFO
- Jan 6, 2017
- Texas Panhandle
- Dan
- K20
I've been using that stuff on my GMT800 windows for several years.After a little more research. That blaster he is using is the Advanced Dry Lube, not the Graphite Dry Lube. The Advanced dry lube uses Teflon, not graphite. Teflon is a brand name, the chemical name for Teflon is (Polytetrafluoroethylene). The WD-40 dry lube has PTFE which might be easier to find depending on where you shop. WD-40 even makes a special window track formulation spray
WD-40.
Before using it, I thought my motors were worn out.
