3 Wire Temp Sender
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I'm doing an LS Swap in the 85 C10 with gauges. How can I wire the 3 wire temp sender from a 97-98 Corvette/Trans Am be used/replace the one wire temp sender and still use the gauge in the 85 C10?
ali_c20
Austria
Alexander
C20, K5
Does the resistance range of the sensor match the gauge? If no your temp readings would always be off.
Camar068
Air Force Supporting Member
10 yrs Air Force
keep googling. Three wire is what you need. You've got the sender. One wire goes to the PCM/ECM and the other goes to ur gauge. It will work. If it's off, it's probably ur gauge or wiring on the truck.
Moderator
@Camar068 has it right. The only reason it's three wires is because it takes place of two sensors that were used on the older engines.
jw23655
