Steering Wheel Too Close '84 C-10
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
Just bought some wheels from this guy at Wheel411.com. He sells some seats also that may help. It was by far the most comfortable seat I ever sat in. He is a tall guy too. Name is Stephen. Very nice guy. Seats are not cheap but if your spending the money to reupholster it may be worth your while. Give him a call. He may be able to help you out. If nothing else he is pleasant to talk to. Ships anywhere. Noticed you are in MS. He is in Tupelo. Check out his Facebook page too. Pics for days...
xm20k
Girard, Ohio
For me it's that my pedals are too far away, seats (TMI buckets) are full forward, and I have a smaller grant wheel and tilt column, but the whole seat needs to move forward 2 more inches. I'm 5-9 190. I've looked around for some kind of way to move the whole seat bracket forward, but I may have too fab something myself.
Bennyt
Surprise
Ben
All your pedals or just gas? Empire fabrication sells a gas pedal relocation that moves it an inch closer to the driver so that the pedals are more in line. I think I paid around $45
Bolted right on
That looks like a standard camaro lt where circa mid 70s with a wrap on it. Also used in Vegas,Astras,Sunbirds all the H bodys. Wow these used be 10.00 all day long.
xm20k
Girard, Ohio
Mainly the gas pedal, Thanks I'll look into it.
vr1967
Mississippi
Virgil
k1500
6.2L turbo
I know of people who have used S10 columns to gain clearance. I’ve got one and a squarebody column on the shelf. Will try to remember to get them out and do a side by side comparison
Oliver
USA
Joe
I always put about 3/4 inch spacers ( washers, thick nut ) under the front two seat bolts to tilt the seat back on all my squares. Might help you.
Nardulli
St Louis
C15
It takes some getting used to, that's for sure. I happen to have a brand new steering column, complete and still in the box, that's a few inches shorter. I ended up ordering two. There may have been bourbon involved. Let me know if you're interested.
Ididit via squarebody syndicate sells a shorter column. Additionally, there are a few shops across the country that will shorten a stock column.
This. These columns are 2" shorter in the cab, but some of the other guys can shorten them in the cab or under the hood side or both. I'm ~5' 7" 210lbs and have always been perfectly comfortable in my truck. I will say going to the smaller Comfort Grip style wheel did make it even better, it's 15" in diameter vs the factory 16"
Sad Sack
Omaha, NE
Goober
C15
Kind of extreme but how about fiberglass racing bucket seats, no padding.
Ronno6
South Mississippi
Ron
Got a link?
Thanks........
grego28
