82sierradude
- Jun 15, 2017
- Pacific NW
- Ben
- C2500
Yes, the only plastic washer is a selective for the pump.I'd replace any plastic thrust washers in there with brass while I was in it.
In addition to what's included in the Jegs 555-62014 kit, here are the new parts. Hopefully, I didn't miss anything critical:
- Bronze thrust washers
- Torrington bearings
- Low roller clutch
- Intermediate roller clutch
- All bushings
- Pump gears
- 2-3 accumulator piston (aluminum)
- Sonnax 34910-05K boost valve
- Center support bolt (cut a 4l80E bolt to size)
I have two governors with original gears that are in good shape, but I may replace the gear on one of them later.
