General Engine Related Talk and Questions
79K10
Sacramento,ca
Ryan
350/th350
Don't throw those buckets out. Somebody will want them
theyre pretty beat up lol ... i think ill look for a 95-99 60/40 bench, i like the arm rest/middle seat setup
79K10
Sacramento,ca
Ryan
350/th350
Maybe the switch is loose and out of adjustment. It's bolted to the column.
yeah i think i'll be pulling the steering wheel off, i went a bought a new ignition swich, maybe this weekend ill have time to get it done
79K10
Sacramento,ca
Ryan
350/th350
so i got the new ignition key lock put in there and it still turns off if i dont hold it forward... smh... any ideas?? im about to just run a switch and put it under the dash and only use the key to unlock the steering lock and start the truck ... the wire thats giving me trouble would be the one that powers the dizzy right? i mean it cuts the motor instantly so im guessing its that, but im really not sure, it has to be in the column somewhere, i just dont want to tear it all apart again
79K10
Sacramento,ca
Ryan
350/th350
problem resolved: i replaced the ignition switch under the dash, it fixed the binding issue and also the engine cutting off issue. looks like im doing a brake master next.
79K10
Sacramento,ca
Ryan
350/th350
anyone have this happen? not sure if i bought a **** gauge or i have a sticking thermo, air pocket, or blockage ... temp will chill at 190, then shoot up to 240 then come back to 190 after about a minute... does this pretty consistently ... what the hell is that about?
79K10
Sacramento,ca
Ryan
350/th350
Changed out the water pump, it was too late to run it up to temp so I'll be doing it tomorrow
79K10
Sacramento,ca
Ryan
350/th350
Gauge doesn't go over 210 but after a long drive it pisses on the floor... Do I need to flush the system again or will replacing the old rad cap fix that? The old cap is beat up ... I'm going to head to Autozone for some brake rotors on my wife's van so I'll pick one up and see
Skweegle89
Oklahoma
The cap would be the cheapest solution. I'd try that first. Do you have your overflow tank hooked up?
350runner
tx
Ceasar
Inside the truck on the floor?
Yes is there a functioning overflow tank setup? I found that drilling a VERY SMALL hole in the flange of the thermostat cured my temp spiking issues during cold start warm up. Just don't drill it too big or it will take forever to warm up. Could be a sticking thermostat too.
79K10
Sacramento,ca
Ryan
350/th350
Overflow tank is attached, it's new thermostat, I boiled it before install and it opened up. I put the new cap on but haven't had a chance to drive it. Back in town tomorrow so I'll take it for a drive. Temp hasn't been all over the place since the new pump and thermostat was installed , pretty much stays at 205-210. Maybe the overflow tank is cracked, I'll have to take a look
pauljosepharsen
prince edward island
paul
250ci
straight 6 to V8 swap
I have a 250 inline 6 and a four speed manual with bull low, and i was wondering if a 350 would bolt on to my tranny the way it is or would i need a new bell housing and cluch
79K10
Sacramento,ca
Ryan
350/th350
Not quite sure if it'll bolt straight up, I think it will... My .02, get a new clutch either way, you'll tear the old one up once you drop in a 350 lol
79K10
Sacramento,ca
Ryan
350/th350
Oh and on my overflow tank, the hose that runs down to it from the rad cap was cracked, that's why it was pissin all over the driveway ...I cut the line and stuck it back on. I'll see if that was all once my carb is back on and I can run it... Someone said the sun pro gauges were ****, might look for a replacement set
It'll bolt right in with V8 mounts. Fan shroud will need changed. What's wrong with the 6? There's plenty of V8 trucks. I'd leave the 6 if it were me. Only thing I'd change, is swap to a non integral head off an earlier 250 or even 230.
Charkmapman
