- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I'd say it's oil pressure, since these motors don't have an oil level indicator. And yes it should be on with key on and the light having power the swtich beeing grounded being that without the motor running and NO oil pressure to take the switch off of ground that completes the circuit for the light. So I'd say your Oil Light IS NOT Operational. How did you do your pinout? Did you convert your Oil SWITCH wire to an a Gauge SENDER wire? So now where does the Oil SWITCH get it's ground from? If that is all correct, then the light is burned out, or there is no power to the light.
Idiot lights should have power as soon as the key is turned to ON. Then anytime a switch is reading a bad signal, it's sends the ground to complete the circuit and turn the light on.
