Gauge cluster F%#k!
FRANKENTRUCK
By The Sea
Pierce
C10 Deluxe Stepside C10
350 with 350 Turbo transmission
I am trying to replace my 81 idiot light gauge cluster with an earlier set that has proper gauges. But I have NO idea how to set up any of it. I was hoping for a tachometer, but cannot afford one right now. So experts, how do I install the new gauges and get them to work? Also, will a 100 MPH speedo that I put in the truck be accurate like my 85 MPH one was with no modifications?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
You will need to move a few pins around. Plus add a temp gauge sending unit and oil pressure gauge sending unit.
I think there's a wiring diagram floating around here somewhere.
And the 100mph hour speedo should be accurate too. To the best of my knowledge, all the speedos run off the same ratio.
FRANKENTRUCK
By The Sea
Pierce
I seem to remember that the wiring diagram was for older trucks. I also think I need certain wires and copper tubing that is not on there now. For instance the oil idiot light is connected to a wire, right? My new oil gauge is mechanical and had a copper tubing stump remaining on it. I wish someone had good step-by-step pictures of this conversion.
RetroC10Sport
Jay
pontiac aztek
Even if you can't readily find a wiring diagram, tracing the circuits is very easy.
You didn't tell us it was a mechanical OP gauge. So yes, you would need to run the tubing and get the correct sending unit.
What you have is a '77-older cluster. Does it have a Volts or Amp gauge?
oneluckypops
Sedalia, Mo.
Luke
If its a 77 and older cluster what is the little pigtail with the blue box for? I dont remember ever seeing that before. any chance of getting a good picture of the backside of it?
oneluckypops
Sedalia, Mo.
Luke
cant be a 77 and later cluster it has a trip odometer.
oneluckypops
Sedalia, Mo.
Luke
You're looking at Iman's pic. This thread is going off topic but not really.
oh i guess i am getting confused. DAMNED Mods need to clean this chit up lol :pokeowned:
RetroC10Sport
Jay
pontiac aztek
Cruise control.
FRANKENTRUCK
By The Sea
Pierce
FRANKENTRUCK
By The Sea
Pierce
I guess I must find the right wires and connectors then.
Chype1
