Z Bar issues SM465 - 350 - NP208
no idea if the Z bar situation is any different with a diff combo, but figured id state it.
Could I see how its supposed to look + let me know if anything here is right... it dont look right.
hunters628
Ellensburg Washington
Hunter
Looks exactly like what I just took apart. So I’d say it’s fine. We’re you having an actual issue? You never said other than the title of the thread that you were.
it looks rigged and bent and bushing is bad where it greases
Curt
Loco Hills
Curt
K-30
Did you find out where to get rebuild parts for the zbar?
Being one side is on the frame and the other on the trans,or block,every zbar I’ve ever seen looks like that.Poor design with to much movement.
I was looking at going to hydraulic shift set up.
is that factory or do you think mine was.. made up?
BigDaddy72
Bentonville Arkansas
Travis
C30 Chassis Cab
I’ve got an entire sm465 set up from flywheel to yoke clutch pedal and everything.
So if you would like individual pics from anything I can get em to ya. Just keep in mind my stuff is for 2wd but up to the trans case all should be very similar.
Yes could you show your assembly? Where it mounts to on both sides?
fast68chevy
I am the original fast68chevy
LINCOLN IL
RANDY
for sale? im trying to find parts to go from th350 in my C20 to 4 speed... i need all of it including the frame rail bracket etc.. PM me if you or anyone has all these parts pieces.. i only know of one truck anywhere near here at a yard that i could get the parts from., if they didnt lose any of the parts when they pulled the 350 out of it.. if they still have it anyways... thx
pduffyd
Melbourne, Australia
Hi, I will give my 5c worth.
I have pulled the z bar system off my 76 C20 with a sm465.
The z bar on mine, at the tranny, had one side pivot bolted into the bellhouse, not engine block. The other side was the frame bracket. My frame bracket was worn out as the pivot bolt on that side had come loose.
My system isnt any good for you as my truck is a right hand drive in Australia.
You can see the big bolt hole on the side of the bellhouse
Im going hydraulic like on the later squares.
Novak also does kits for the slave cylinder, or maybe Wilwood? This will need a clutch folk change maybe, which I have done.
Thete are a few links on this site about this, and also about z bar stuff.
https://www.gmsquarebody.com/threads/upgrading-your-square-with-a-hydraulic-clutch.6589/
https://www.gmsquarebody.com/forums/manual-transmission-clutch.47/
Does your truck have a bed? That fuel neck is really far back unless im mistaken on what that is
pduffyd
Yep thats the fuel neck, its a long wheelbase cab chassis. 131.5" wb.
Im doing a restomod, 75 chassis with a 59 cab/body. Well gotta save money now to buy the sheet metal. I have a build thread going. Its got a 454 with my rebuilt 4 speed 465. I got rid of the side tank, and got a 31 gal in the back like a Blazer.
If you are interested.
https://www.gmsquarebody.com/threads/aussie-rhd-1975-c20-2wd-resto-mod.27602/
pduffyd
looks like you are doing lots of work on your square. Keep going it will all pay off, for a fun and reliable truck
Hunt1
