Write up: Gas Tank Relocation
Not required but does make it easier.
350runner
tx
Ceasar
Ok thanks
87R10
Ontario, Canada
Scott
I have thought about it but have not done any meaningful research on it. I do know that you'd want a tank where the filler neck is at the license plate so a tank from a car like an old Camaro, early 90's B Bodies, many cars from the 70's,..... that'd be your starting point then it'd be about planning out how to mount it in the rear. I'm sure it's doable with just a little planning and mild fabrication work :)
I wouldn't do that, those cars SUCKED when filling them...cant fill too fast.
I'm modifying my box to have a blazer fuel door in front of the tailight
My 91 Caprice with the fill up behind the plate was easy to fill up :shrug: no issues at all
87R10
Ontario, Canada
Scott
the 90's cars might not have been bad, but the early 70's novas were terrible. I worked in a gas station as a kid. Some lady drove her POS 4 door ventura in during a heavy rainstorm...shoved $5 out a window barely cracked open...the nozzle clicked off several times before I even hit $3 bucks...I dumped the rest on the ground.....
350runner
tx
Ceasar
The epa is now your friend lol
87R10
Ontario, Canada
Scott
Lol...I was a kid with a bad attitude back then. I would not think of doing something like that now. I would not classify myself as a tree hugger but I do care a lot more about the environment now and try to do my part within reason.
350runner
tx
Ceasar
If I hadn't added it yet in this thread, will do so now. After having a 40 gallon Burb tank and taking measurements, I don't think the 40 gallon is a safe fit for even a longbed pick up. I won't be doing it. I'd do the 31 gallon tank as done here since it's 7 inches shorter in length than the 40 gallon.
Sueco
Puerto Vallarta
C10 Cheyenne
I'm replacing my tanks with plastic universals(Becuase the old ones are rusted out). New original tanks are hard to find down here. I need range for my truck, having some plans for putting in even bigger ones or a third one. If I could fill it up once then run continously for about 1300km(800 miles?) I'd be very happy.
Thanks for the write-up!
350runner
tx
Ceasar
While at the yard the other day I stumbled across a gas tank shaped like a box. Kinda like a fuel cell. It was said to be out of a f250 I started thinking about getting it as everyone wants $100 for a used burb tank. I'm looking around but no luck. Anyone in the dfw know where to find a cheap tank and sending unit ?
John81287
Mchenry,IL
V20
So I'm gonna be doing this real soon to my truck any advice? @Old77
Sent from somewhere in Northern Illinois!
Feel free to add more pics of your swap to this thread, and other ideas or methods you used doing yours.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I used blazer x members to put the blazer tank in my crew cab
I had to modify the front one a little. basically I cut the ends off moved them up 2'' and welded them back on and braced them
the truck frame steps up over the rear axle where the blazer one is straight that's why I had to modify the x member
worked really well used stock blazer x members straps and tank
MadOgre
NA
NA
NA
NA
NA
:lol: There's all kinds of obstacles between the rear of the truck to the original filler location to make that idea near impossible :D
I think the obstacle is the tank. a custom tank would make this project much easier and would allow for proper use of the original fuel doors
I also don't like how close the tank is to the rear bumper. IMO that's just as dangerous if not more so then the saddle tanks.
Garcjay
