Wiring question.
blueburb2500
New Bern, North Carolina
Elliott
Suburban 2500
Hello everyone. I am troubleshooting my cruise control and I’m reading out power on my connector for the cruise control module. I’m supposed to have 12volts at pin F according to my alldata troubleshooting schematic. It’s also telling me that pin E should be a ground. On my connector on the truck there is no wire or terminal on pin e. Is this correct ? On the tsb photo it’s showing a pin e to ground but on the wiring diagram it’s showing it’s empty.
Snoots
Roger
Jimmy Sierra
350 w/203
Could it possibly be a case ground (internally grounded)?
gmbellew
Kansas city
glen
suburban 1500
I'd look at the wiring diagrams in the reference library of this site to be sure you are looking at the right stuff.
blueburb2500
Elliott
Suburban 2500
Yeah I’ll go there now. I’ve never had a problem with alldatas wiring schematics I’m wondering if the tsb is for a different model truck? Maybe obs truck
blueburb2500
Elliott
Suburban 2500
So not sure which one to go by. Using the Diagram in the tech library for my truck a 1990 suburban. It’s telling me my brake light switch wires should be gray/black and brown on one switch and the other switch should be Brown and Gray. Mine are gray/black and gray for the first switch and orange and white on second switch.
gmbellew
Kansas city
glen
suburban 1500
not sure what you are looking at. grey/black and grey is right for an automatic transmission cruise brake switch. section A pg 114. the other switch may be for the TCC?
