Wipers run backwards
Paul Rose
Alabama
K-20
Rebuilt 85 K20- with painless wiring harness. All works as it's supposed to even delay but wipers actually run backwards. When shut off they park in the up position. I suspect a wiring issue but I can't find a definitive diagram of wiring. Any ideas?
Thanks for the help.
Itali83
Maine
Ben
K10, 'burban C10, Jimmy
Did you literally just replace the wiring and not touch ANYTHING with the wiper motor or linkage? You should have a constant 12volt ignition power to the motor for the park circuit. I forget which wire it is but there’s only a few wires at the motor.
Ben.
gmbellew
Kansas city
glen
suburban 1500
there is a park switch in the motor assembly I think. it may be something with the linkage and the switch.
Doppleganger
OH-MI: Just like it sounds
Sounds like the linkage is out of sync. Used to have that on wagon rear wipers all the time.
Scott91370
Burleson, Tx
Scott
Sierra1500
Paul Rose
Alabama
K-20
Ben.
Ben,
We had it all apart, linkage and all. Seems like the linkage may be 180 degrees out? Changing the wiring on the motor shouldn't make it run a different direction I wouldn't think. But then I've been wrong before!!!
Itali83
Maine
Ben
Ok that’s what I wanted to know. Yes for sure your linkage is out of time. You need to make sure the motor is in the park position, the. Set the linkage to get the wipers in the correct park position. That’ll get things straightened out for ya.
Ben
Paul Rose
Alabama
K-20
Ben
Thanks Ben!!!
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
https://www.gmsquarebody.com/threads/1973-1991-wiring-manuals.14498/
Sounds to me like someone reinstalled the linkage 180 degrees out or the motor was 180 out when it was installed.
Remove the motor, put the wipers in the down position and install the motor.
Pull wipers off. Run motor. Turn motor off. Reinstall wipers in correct position. Drink beer.
These both sound like solid advice to me (especially the one with beer). Can't imagine how it would be a wiring issue
Squirrely Brother
Dallas, TX
Alan
I just had the same issue when I replaced my wiper motor. Your linkage for whatever reason is pointing towards the drivers door. Remove the motor, move the linkage arm connector to orientate to the passengers door, have your wipers in the down position, secure all the hardware and you’ll be good to go. I thought I bought a defective motor, tried re-orientating the wipers, which was a pain in in the ass, but no it was an easy linkage fix. You should be able to fix it in less than 5 minutes. Super easy to do.
CRM
Pasco, Washington
Casey
K2500
350 CI
So the wipers don't run backwards, they stop backwards (JK).......linkage as others have said.
Paul Rose
Alabama
K-20
The linkage was the problem. All works as it's supposed to after re-orienting it. Thanks for all the help!!
cutlerfab
